POV-Ray : Newsgroups : povray.general : DemtoPov... Server Time
12 Sep 2025 03:00:15 EDT (-0400)
  DemtoPov... (Message 1 to 5 of 5)
Subject: DemtoPov...
Date: 24 Apr 2001 12:03:21
Message: <3AE5A3B7.82AC4D05@sympatico.ca>
Alex,  from Quebec,  Canada.
....  I thought it was the good forum to ask my question.
I downloaded DEM datas and learned I had to use
Dem_to_Pov in order to be able use it into Pov;  So,
I downloaded the freeware,  but I would like to know
if I will be able to use the tga. file into PovWin  (the window version)
I don't understand DOS anymore (but could do a little...),
so is there another way of converting Dem datas into Pov for window ?!
Thanx,            Alex Pilote
http://www3.sympatico.ca/floral.audet/index.html
Subject: Re: DemtoPov...
Date: 24 Apr 2001 12:21:45
Message: <3ae5a819$1@news.povray.org>
"Al_Canada" <flo### [at] sympaticoca> wrote in message
news:3AE5A3B7.82AC4D05@sympatico.ca...
AFAIK there is no difference between the functionality of povdos and povwin
(or indeed any pov on any o/s).
The only difference is in the interface to the application.
Date: 24 Apr 2001 12:24:34
Message: <3AE5A8D2.998C7031@gmx.de>
> Thanx,            Alex Pilote
I don't know about the Dem_to_Pov program you mentioned, but you can
surely use a tga file as a heightfield/image_map in every version of
Povray.
Conversion depends on what format you have the DEM in.  There are some
programs capable of importing and exporting a lot of different DEM file
formats, you might want to check the Povray links page:
http://www.povray.org/links/3D_Programs/Height_Field_Modelling_Programs_and_Utilities/
Date: 24 Apr 2001 13:02:17
Message: <slrn9ebccr.4bq.ron.parker@fwi.com>
That's not entirely true.  The "sys" format varies from OS to OS.  Windows
uses BMP, for example, while Mac uses PICT.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 24 Apr 2001 14:54:47
Message: <3AE5CBE7.EC2D6C7E@sympatico.ca>
on)
> > Thanx,            Alex Pilote
> Povray.
_and_Utilities/
> Christoph
Thank you all;  (in fact,  the software I was talking about is called
DEM2POV...)  But I looked on the povray.org,  and I think there
are some easier conversion programs to work with... I mean easier
than DEM2POV.
I wll try it.
                          Alex
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
