Alex, from Quebec, Canada.
.... I thought it was the good forum to ask my question.
I downloaded DEM datas and learned I had to use
Dem_to_Pov in order to be able use it into Pov; So,
I downloaded the freeware, but I would like to know
if I will be able to use the tga. file into PovWin (the window version)
I don't understand DOS anymore (but could do a little...),
so is there another way of converting Dem datas into Pov for window ?!
Thanx, Alex Pilote
http://www3.sympatico.ca/floral.audet/index.html
"Al_Canada" <flo### [at] sympaticoca> wrote in message
news:3AE5A3B7.82AC4D05@sympatico.ca...
AFAIK there is no difference between the functionality of povdos and povwin
(or indeed any pov on any o/s).
The only difference is in the interface to the application.
> Thanx, Alex Pilote
I don't know about the Dem_to_Pov program you mentioned, but you can
surely use a tga file as a heightfield/image_map in every version of
Povray.
Conversion depends on what format you have the DEM in. There are some
programs capable of importing and exporting a lot of different DEM file
formats, you might want to check the Povray links page:
http://www.povray.org/links/3D_Programs/Height_Field_Modelling_Programs_and_Utilities/
Christoph Hormann <chr### [at] gmxde>
That's not entirely true. The "sys" format varies from OS to OS. Windows
uses BMP, for example, while Mac uses PICT.
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
on)
> > Thanx, Alex Pilote
> Povray.
_and_Utilities/
> Christoph
Thank you all; (in fact, the software I was talking about is called
DEM2POV...) But I looked on the povray.org, and I think there
are some easier conversion programs to work with... I mean easier
than DEM2POV.
I wll try it.
Alex
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
