POV-Ray : Newsgroups : povray.general : [bug] declared normal on camera Server Time
24 Aug 2025 20:54:26 EDT (-0400)
  [bug] declared normal on camera (Message 1 to 5 of 5)
Subject: [bug] declared normal on camera
Date: 12 Mar 2001 05:19:52
Message: <3AACA239.E380A0E2@skynet.be>
The following piece of code makes POV-Ray (under Windows, both
official and unofficial) exit, without any message, once the rendering
is complete :
#declare Cam1 = camera {location <500,150,-250>
                        direction z*1
                        look_at <0,150,120>
                        normal {bumps .1}
camera {Cam1}
This happens when the camera is declared AND there is a normal
statement in the camera.  Not very annoying, since it's easy to
turn around, but still a bug.
Fabien.
Subject: Re: [bug] declared normal on camera
Date: 12 Mar 2001 21:46:59
Message: <f92ratk0hl2e5g0l1uop0dq7npi70ald3k@4ax.com>
>is complete :
  Hi, Fabien. Are you using the vc++ compiled version of v3.1g or the
Watcom? Not sure if it makes a difference but it may help us track things...
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 13 Mar 2001 03:30:57
Message: <3AADDA34.3A2F00F3@skynet.be>
Strangely, as I redid the test, the crash now occured BEFORE rendering,
go figure...
The problem is exactly the same with
- 3.1g official Watcom.
- MegaPOV 0.7
- MLPOV (MP 0.7 + aoi patch) msvc compiled.
I'm using Windows ME on a Celeron 633, 128 Mb.
Fabien.
Date: 28 Mar 2001 06:50:48
Message: <3AC1D01B.46A33EC7@nanterre.marelli.fr>
> go figure...
> - MegaPOV 0.7
> Fabien.
Well, with a unix version, in POV 3.1g, POV exits (without crashing)
before the rendering, with the following message:
"Warp type 16384 not yet implemented"
Doing the same test with POVMan 0.62 (unix) ends OK (no bug, no crash).
Bouf.
Date: 4 Apr 2001 05:51:43
Message: <3ACAEED7.1F6DC2C1@aetec.ee>
> is complete :
Bug reason is probably found by POV-Team, but just for case...
Christophe Bouffartigue released POVMan 0.71.4, which has corrected this
bug.
For correction line with + should be added to Copy_Camera() function in
file camera.c:
    New = Create_Camera();
    *New = *Old;
+   New->Tnormal = Copy_Tnormal(Old->Tnormal);
