The syntax highlighter used in the various versions of POV for windows
thinks atan() is a valid function.
Have I discovered a new bug? Should I post to povray.bugreports?
Francois Labreque | Rimmer: "Let's go to red alert!"
flabreque | Kryten: "Are you sure, Sir? You realize it
@ | actually means changing the bulb!"
videotron.ca
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Try to post it to povray.unofficial.patches...
<p>Francois Labreque wrote:
<blockquote TYPE=CITE>The syntax highlighter used in the various versions
of POV for windows
<br>thinks atan() is a valid function.
<p>Have I discovered a new bug? Should I post to povray.bugreports?
<p>--
<br>Francois Labreque | Rimmer: "Let's go to red alert!"
<br> flabreque | Kryten: "Are
<br>
| actually means
changing the bulb!"
<br> videotron.ca</blockquote>
</html>
No - atan() *is* invalid. POV-Ray 3.1 only supports the atan2() function,
with instructions in the docs to use atan2(A, 1) if you want something that
acts like regular atan().
I know this, but atan() is highlighted in purple as if it were a valid
keyword. Hence my question.
However, I think this is a problem with the Codemax editor, not the
POV-Ray (or MegaPOV) program. Hence my asking if I should post my bug
report to p.br.
videotron.ca
> report to p.br.
Mea culpa - I read your original message back to front! So, I guess I
should reply back to front as well - a quick perusal of the MegaPOV docs
reveals that atan() *is* valid in isosurfaces, so it would appear that it's
not a bug when using the editor with MegaPOV...
> > report to p.br.
But... but... but... it also does it with P.O.V. (Plain Ol' Vanilla) POV
as well!!!
videotron.ca
> > > valid keyword. Hence my question.
> > > the POV-Ray (or MegaPOV) program. Hence my asking if I should
> > > post my bug report to p.br.
> > guess I should reply back to front as well - a quick perusal of the
> > MegaPOV docs reveals that atan() *is* valid in isosurfaces, so it
> > would appear that it's not a bug when using the editor with
> > MegaPOV...
> as well!!!
The atan keyword (without parentheses) can be used in the julia object
in the official version.
John
> > > MegaPOV...
> > as well!!!
Oh! I did not know that!
videotron.ca
