![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi there,
Does anyone have suggestions for generating a night sky with stars? A big
spehere with random holes punched through it? :) I obviously can't use
light to illuminate a sky_sphere.
Yann
Yann Ramin atr### [at] atrustrivalie eu org
Atrus Trivalie Productions www.redshift.com/~yramin
Monterey High IT www.montereyhigh.com
AIM oddatrus
Marina, CA
IRM Developer Network Toaster Developer
SNTS Developer KLevel Developer
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Yann Ramin" <atr### [at] atrustrivalie eu org> wrote in message
news:39d2d4cd@news.povray.org...
Easiest thing to do is use the star texture on a sky_sphere, it's in the
texture.inc file which comes with POV. In MegaPov there's a post process
kind too.
Second easiest would be to use the galaxy.inc from Chris Colefax, or one of
the others people have done already. There is one which mimics the true
stellar sky using Hubble data I believe.
I can't go looking much now for specific ones but at:
http://www.btinternet.com/~consty/render/render_f.htm
go to the Utilities then POV files and there'll be both a link to Chris
Colefax's site and a 3D Starfield file.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
and turn up up the ambient in its the finish{} statement to make the stars
light up (with radiosity turned on these can practically become light
sources).
Dan D.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> kind too.
Post processing is better, because you don't have problems with
antialiasing, which usualy eats all stars ;-).
> Bob
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> sources).
I think, that they are too small for it...
Disnel
> Dan D.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yann Ramin <atr### [at] atrustrivalie eu org> wrote in message
> Hi there,
I generally use some version of the following
#declare StarNo=0;
#declare rndPos=seed(8932)
#while (StarNo<1000) // change value for more or less stars
sphere {
<1000,0,0>,1 // change numbers according to scale of scene
pigment {rgb 1}
finish {ambient 0.9}
rotate <360*rand(rndPos),360*rand(rndPos),360*rand(rndPos)>
#declare StarNo=StarNo+1
Gail
* gsh### [at] monotix co za * System.dat not found. *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k *
* If at first you don't succeed, call it version 1.0 *
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Gail Shaw <gsh### [at] monotix co za> wrote:
: sphere {
: <1000,0,0>,1 // change numbers according to scale of scene
: rotate <360*rand(rndPos),360*rand(rndPos),360*rand(rndPos)>
This has two main problems.
Firstly, the sphere is located in the x-axis (at <1000,0,0>), so the
first rotation (which is around the x-axis) will have no effect.
Secondly, rotating an evenly random angle around the y-axis and then
an evenly random angle around the z-axis has an undesired effect: You
will have more stars near the y-axis (ie. around <0,1000,0>) than near
the x-z plane.
That is, the stars are not evenly scattered around the sky but there are
more stars directly "up" than near the "horizon".
If you want an even distribution of stars you have to use a bit more
complicated algorithm. For example:
1) Calculate a random point inside a sphere (eg. a unit sphere). The
random distribution must be even.
2) Translate this point in the direction origin-point (ie. multiply it by
a value) so that its distance from the origin will be the desired (eg. 1000).
For example something like this:
#declare Stars = 1000;
#declare Distance = 1000;
#declare StarRadius = 1;
#declare Seed=seed(0);
#local Ind=0;
#while(Ind<Stars)
#local Location = <-1+rand(Seed)*2, -1+rand(Seed)*2, -1+rand(Seed)*2>;
#while(vlength(Location) > 1)
#local Location = Distance*Location/vlength(Location);
sphere { Location, StarRadius pigment { rgb 1 } finish { ambient 1 } }
#local Ind=Ind+1;
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Warp!
Just curios: Why the inner loop? I don't see a reason to keep the length of
Location below 1.
vlength(Location/vlenth(Location)) is always 1 isn't it?
Or is it already too late at night?
KK
> #local Ind=0;
> #while(Ind<Stars)
> #end
> #local Ind=Ind+1;
> #end
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Location below 1.
Warp's code evenly distributes points within a cube at the origin. In order to
make an even spherical distribution, only the subset of these points within a
sphere that fits inside the cube is taken. The point is then moved to a fixed
distance from the origin.
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sorry: too late at night...
Having turned of the computer yesterday, i realized my fault.
Thanks!
KK
order to
within a
fixed
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
