POV-Ray : Newsgroups : povray.general : Star night sky Server Time
25 Mar 2026 23:25:15 EDT (-0400)
  Star night sky (Message 1 to 10 of 20)
Subject: Star night sky
Date: 28 Sep 2000 01:19:09
Message: <39d2d4cd@news.povray.org>
Hi there,
Does anyone have suggestions for generating a night sky with stars?  A big
spehere with random holes punched through it? :)  I obviously can't use
light to illuminate a sky_sphere.
Yann
Yann Ramin                      atr### [at] atrustrivalieeuorg
Atrus Trivalie Productions      www.redshift.com/~yramin
Monterey High IT                www.montereyhigh.com
AIM                             oddatrus
Marina, CA
IRM Developer                   Network Toaster Developer
SNTS Developer                  KLevel Developer
Subject: Re: Star night sky
Date: 28 Sep 2000 01:35:39
Message: <39d2d8ab@news.povray.org>
"Yann Ramin" <atr### [at] atrustrivalieeuorg> wrote in message
news:39d2d4cd@news.povray.org...
Easiest thing to do is use the star texture on a sky_sphere, it's in the
texture.inc file which comes with POV.  In MegaPov there's a post process
kind too.
Second easiest would be to use the galaxy.inc from Chris Colefax, or one of
the others people have done already.  There is one which mimics the true
stellar sky using Hubble data I believe.
I can't go looking much now for specific ones but at:
http://www.btinternet.com/~consty/render/render_f.htm
go to the Utilities then POV files and there'll be both a link to Chris
Colefax's site and a 3D Starfield file.
Date: 28 Sep 2000 01:42:55
Message: <39d2da5f$1@news.povray.org>
and turn up up the ambient in its the finish{} statement to make the stars
light up (with radiosity turned on these can practically become light
sources).
Dan D.
Date: 28 Sep 2000 08:24:06
Message: <39D3394B.6C243333@hlavacek-partner.cz>
> kind too.
Post processing is better, because you don't have problems with
antialiasing, which usualy eats all stars ;-).
> Bob
Date: 28 Sep 2000 08:24:45
Message: <39D33972.B13A4F09@hlavacek-partner.cz>
> sources).
I think, that they are too small for it...
Disnel
> Dan D.
Date: 28 Sep 2000 08:36:50
Message: <39d33b62@news.povray.org>
Yann Ramin <atr### [at] atrustrivalieeuorg> wrote in message
> Hi there,
I generally use some version of the following
#declare StarNo=0;
#declare rndPos=seed(8932)
#while (StarNo<1000)  // change value for more or less stars
 sphere {
   <1000,0,0>,1   // change numbers according to scale of scene
    pigment {rgb 1}
    finish {ambient 0.9}
   rotate <360*rand(rndPos),360*rand(rndPos),360*rand(rndPos)>
 #declare StarNo=StarNo+1
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 28 Sep 2000 10:04:53
Message: <39d35005@news.povray.org>
Gail Shaw <gsh### [at] monotixcoza> wrote:
:  sphere {
:    <1000,0,0>,1   // change numbers according to scale of scene
:    rotate <360*rand(rndPos),360*rand(rndPos),360*rand(rndPos)>
  This has two main problems.
  Firstly, the sphere is located in the x-axis (at <1000,0,0>), so the
first rotation (which is around the x-axis) will have no effect.
  Secondly, rotating an evenly random angle around the y-axis and then
an evenly random angle around the z-axis has an undesired effect: You
will have more stars near the y-axis (ie. around <0,1000,0>) than near
the x-z plane.
  That is, the stars are not evenly scattered around the sky but there are
more stars directly "up" than near the "horizon".
  If you want an even distribution of stars you have to use a bit more
complicated algorithm. For example:
  1) Calculate a random point inside a sphere (eg. a unit sphere). The
random distribution must be even.
  2) Translate this point in the direction origin-point (ie. multiply it by
a value) so that its distance from the origin will be the desired (eg. 1000).
  For example something like this:
#declare Stars = 1000;
#declare Distance = 1000;
#declare StarRadius = 1;
#declare Seed=seed(0);
#local Ind=0;
#while(Ind<Stars)
  #local Location = <-1+rand(Seed)*2, -1+rand(Seed)*2, -1+rand(Seed)*2>;
  #while(vlength(Location) > 1)
  #local Location = Distance*Location/vlength(Location);
  sphere { Location, StarRadius pigment { rgb 1 } finish { ambient 1 } }
  #local Ind=Ind+1;
Date: 28 Sep 2000 16:19:20
Message: <39d3a7c8@news.povray.org>
Hi Warp!
Just curios: Why the inner loop? I don't see a reason to keep the length of
Location below 1.
vlength(Location/vlenth(Location)) is always 1 isn't it?
Or is it already too late at night?
KK
> #local Ind=0;
> #while(Ind<Stars)
>   #end
>   #local Ind=Ind+1;
> #end
Date: 28 Sep 2000 21:02:53
Message: <39D3E7FA.15D62A5D@faricy.net>
> Location below 1.
Warp's code evenly distributes points within a cube at the origin. In order to
make an even spherical distribution, only the subset of these points within a
sphere that fits inside the cube is taken. The point is then moved to a fixed
distance from the origin.
Date: 29 Sep 2000 02:33:50
Message: <39d437ce$1@news.povray.org>
Sorry: too late at night...
Having turned of the computer yesterday, i realized my fault.
Thanks!
KK
order to
within a
fixed
