POV-Ray : Newsgroups : povray.general : POV Includes note Server Time
13 Sep 2025 03:31:31 EDT (-0400)
  POV Includes note (Message 1 to 9 of 9)
Subject: POV Includes note
Date: 28 Sep 2000 08:21:40
Message: <39D338B9.6750D83A@hlavacek-partner.cz>
It can be useful to enable multiple #include of some file
to POV source (for example when I include colors.inc in
my main POV file a it is also included in some other
include).
It can be done like C includes:
#ifndef (_INCLUDE_NAME)
  #declare _INCLUDE_NAME=yes;
.... include file content ....
Disnel
Subject: Re: POV Includes note
Date: 28 Sep 2000 10:06:42
Message: <39d35071@news.povray.org>
Also includes that need other includes should include those themselves.
  For example, if textures.inc needs colors.inc, then textures.inc should
Date: 28 Sep 2000 10:46:39
Message: <39D359CF.7DAE8354@spiritone.com>
I thought that including a file like "colors.inc" increased the memory usage
or had some other effect to slow down parsing.
Josh
eng### [at] spiritonecom
Date: 28 Sep 2000 11:05:18
Message: <39d35e2d@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote:
: I thought that including a file like "colors.inc" increased the memory usage
: or had some other effect to slow down parsing.
  But if textures.inc doesn't include colors.inc then it will not parse at
all (unless you have included colors.inc yourself).
Date: 29 Sep 2000 05:19:23
Message: <39D45E9B.380C6DB@itam.cas.cz>
But if you inlude texture.inc, for example, you NEED colors.inc,
regardless
if it is included automatically from  textures.inc or manually from your
POV file before #include "textures.inc".
> Josh
> Josh English -- Lexiphanic Lethomaniac
> The POV-Ray Cyclopedia http://www.spiritone.com/~english/cyclopedia/
Date: 29 Sep 2000 08:49:11
Message: <39d48fc7@news.povray.org>
> regardless
Does POV make sure it hasn't already included a particular include?  I think
not, or a lot of the include file style functions wouldn't work multiple
times.  Parsing a long include of essentially just definitions (even if they
overwrite only themselves) could take quite a bit of time, if it's a long
file.
So there is some use in checking to see if a particular include (not of the
type where including multiple times can have different results) has already
been included.
Geoff
Date: 29 Sep 2000 08:57:55
Message: <39D491D2.AB8632AE@itam.cas.cz>
I tried following:
test.pov:
#include "test1.inc"
#include "test2.inc"
test1.inc:
#debug "\ntest1.inc included\n"
test2:inc:
and then:
POV_Mega +itest.pov
.... pov mesasges ...
Parsing...
test1.inc included
test1.inc include
 <----ERROR
test1.inc:2: error: No objects in scene.
So, included test1.inc two times.
If I understand you correctly, then such check would disallow recursive
tricks with includes.
> > regardless
> file.
> been included.
> Geoff
Date: 29 Sep 2000 18:01:22
Message: <slrn8t9tdl.r5e.hjp-usenet@teal.h.hjp.at>
No. But see below.
>I think not, or a lot of the include file style functions wouldn't work
>multiple times.
Yes.
>long file.
>the type where including multiple times can have different results) has
>already been included.
In C the standard way to avoid including files twice has always been
to put something like
#ifndef __this_file_INCLUDED__
    #define __this_file_INCLUDED__
#endif
around the whole file. If you look at colors.inc, you can see that
povray uses a similar technique.
However, while this prevents any untoward effects of redeclaring
variables, and speeds up the parsing of the file quite a bit, it doesn't
normally prevent the compiler (or povray) from parsing the file a second
(and third, fourth, ...) time, so it isn't as fast as it could be.
Gcc uses two tricks to prevent that:
Firstly, it introduced a directive #import, which was similar to
#include, but would do nothing if the file had already been imported.
Being gcc-specific, this didn't help programs designed to be portable
and is rarely used. Povray doesn't have this problem, so this solution
might be viable for povray.
Secondly, the compiler[1] checks whether the include file conforms to
the #ifndef MACRO; #define MACRO; ...; #endif layout, and if it does,
it won't include the file again if MACRO is defined. This is a bit more
complicated but helps existing scene files. (But if someone want's to
implement this, DON'T take the code from cccp, the GPL is incompatible
with povray's license).
	hp
[1] Actually the preprocessor, cccp.
|_|_) | Sysadmin WSR       | vor dem rechner.
__/   | http://www.hjp.at/ |       at.linux, 2000-09-24
Date: 3 Oct 2000 04:58:12
Message: <39d99fa4@news.povray.org>
If you include a common *.inc file in every file that need it, when you
include these files, you parse the common file multiple time, which can be
slow. What I do is check with ifndef if the file isn't already included (by
checking either the first #declared identifier in the #included file or the
first #declared identifier the current file needs from the #included file).
Povingly,
Philippe
