POV-Ray : Newsgroups : povray.general : From contours to 3D modells in POV Ray Server Time
21 Jun 2026 06:46:48 EDT (-0400)
  From contours to 3D modells in POV Ray (Message 1 to 6 of 6)
Subject: From contours to 3D modells in POV Ray
Date: 24 Aug 2000 06:18:19
Message: <39A4F66C.B4F4B4C3@hotmail.com>
Hi everyone!
I need some help! I've got a stack of 2D images that represents a series
of cross sections through an object. (This is biological data: sections
through animal tissue) I am trying to reconstruct certain structures
from this stack of images. Up to now I have been using a program called
IGL trace to draw contours around these structures in all of the images
and then exporting this information as a VRML object. Then I have to
convert it to POV format. Unfortunately the objects appear to be quite
"chuncky" in both VRML and POVRAY.
Is there some direct way to create a 3d modell (POVRAY) from a series of
contours?
Thanks a lot for any help!
Rene (rhe### [at] hotmailcom)
Subject: Re: From contours to 3D modells in POV Ray
Date: 24 Aug 2000 11:51:04
Message: <8F9AB4F84seed7@204.213.191.228>
>contours?
Not a direct way, but you could try to put all your contour images into a
df3 file. Use the df3 as a funtion in an isosurface object or use it with
emitting media to recreate the object.
Also your original stack of 2D slices can be put in a df3 file.
Ingo
Date: 24 Aug 2000 11:51:46
Message: <39a54492@news.povray.org>
There's no universal way to convert 2D cross-sections and/or projections
to 3D objects in an unambiguous way (except perhaps in few cases).
Date: 24 Aug 2000 12:07:57
Message: <39A54887.50B55446@schunter.etc.tu-bs.de>
ingo wrote:
> >contours?
Better to use the df3 as an isosurface function instead.
Date: 24 Aug 2000 15:41:54
Message: <39A57A2B.5B5ED52E@yahoo.com>
If you are from an university: Most "mechanical" institutes have a modern
3d-CAD-system. Perhaps you find someone who creates a surface by a "loft".
It takes (if your cross-sections are ok) about 2 minutes. Export then a
stl-file and convert it to pov-input.
jurek
Date: 26 Aug 2000 01:28:04
Message: <39A755A0.BFCDC48D@insectes.net>
> contours?
If you have access to a Linux box, try Moonlight Atelier's "Skin" You draw
your profiles (I'm not sure if you can load in your images as a background
while you draw, I never tried), and then select them in order (they turn red
as you select them) and it will create a smooth surface through them, with
NURBS. You might have difficulty closing the ends off though...
http://www.moonlight.stpinkert.de/   to download if you don't have it, or if
you have a SuSE 6.4 cd, it's on it.
