POV-Ray : Newsgroups : povray.general : Anybody know this site? Server Time
12 Sep 2025 07:52:45 EDT (-0400)
  Anybody know this site? (Message 1 to 10 of 25)
Subject: Anybody know this site?
Date: 11 Aug 2000 23:06:19
Message: <3994bf2b@news.povray.org>
I'm trying to find a website:  it had an excellent tutorial on turning flat
bitmaps of rocks into heightfields.  The guy also had an image gallery
with pictures of an indoor swimming pool (POV-Ray generated).
Sorry, that's really all I have to go on... anybody know this site?
- Doug Eichenberg
  http://www.getinfo.net/douge
  dou### [at] nlsnet
Subject: Re: Anybody know this site?
Date: 11 Aug 2000 23:38:14
Message: <3994C6BC.284C0028@kivisalo.net>
I know this site. There is also that teapot picture from pov Hall of Fame.
http://www.kivisalo.net
K.K.
Date: 12 Aug 2000 04:45:14
Message: <8F8E60FAAseed7@204.213.191.228>
>Fame. http://www.kivisalo.net
I like your Level Connector.
It makes me wonder, would something like this also be possible in 3d-
space? A level_connect warp? It would be nice in combination with Chris'
object pattern and other colour list pigments.
Ingo
Date: 12 Aug 2000 08:37:33
Message: <39954523.5752D334@kivisalo.net>
> space?
I like to think this as a simple electrical potential, so it can
be extented to 3d. Time and memory consumption would be too high
with the iterative method currently used. FFT would be more efficient
way to solve the potential field. I have to think about this :)
Just as in 2d the input and solution would be discrete. In 3d
that would be discrete volumes of densities. I can see this
had media applications but not sure if it can be used for surface
generation, maybe with isosurface functions.
Can someone lend me a Cray for the 3D FFT calculations :)
K.K.
Date: 12 Aug 2000 10:38:18
Message: <3995615a$1@news.povray.org>
That's the one Kari!  (Nice site, BTW).  Thanks!
- Doug Eichenberg
  dou### [at] nlsnet
Date: 12 Aug 2000 11:36:45
Message: <chrishuff-3B5DCE.10375112082000@news.povray.org>
In article <39954523.5752D334@kivisalo.net>, Kari Kivisalo
This looks like it could be a useful enhancement for the proximity
pattern(it could solve the grainyness problem)...or something to be
applied to any pattern. Could you give more details on how you calculate
it? I didn't see an in-depth explanation on the site.
Date: 12 Aug 2000 12:49:12
Message: <3995801A.AC206C81@kivisalo.net>
Here is the theory on 2d electrical potential and how to obtain numerical
approximation using difference equations and iterations. This can be solved
with FFT also but I don't yet know how. Should be easy enough to find:
"solving poisson with fft". Numerical Recipes has nice code for 3D FFT
which calculates the solution in-place saving memory.
Laplace: u(xx) + u(yy) = 0
u(xx) = 2nd derivative of u over variable x
Here u is potential (hf height). x and y are hf coordinates.
Resulting difference formula in free areas (x,y) + 1 pixel boundary:
u(x+1,y) + u(x,y+1) + u(x-1,y) + u(x,y-1) = 4*u(x,y)
So basically the procedure is: Take surrounding 4 pixels and put
the average in the middle. Repeat for all free pixels (x,y). If
there are n free pixels the resulting linear system is n*5. I solve
this with Gauss-Seidel iteration.
More on this method in Advanced Engineering Mathematics by Kreyszig
in section Numerical methods for differential equations.
I sent this uncleaned code to the Terragen guy and he made it a new filter.
LevelConnector uses these pseudo functions to communicate with the
rest of the app.
  SetHeight(x, y, hv);
  hv=GetHeight(x, y);
  Sel=GetSelValue(x, y); // is pixel selected
  PixV=HVToFloat(hv);    // convert from internal type to float
  hv=FloatToHV(PixV);    // convert to internal type
//def for the compare func used by bsearch
typedef int (*fptr)(const void*, const void*);
int compare(const int *a,const int *b)
  return(*a - *b);
// The main calculations. Processes data in u[].
// Solves this Laplace's 2nd order differential
// equation using Gauss-Seidel iteration.
//   d2u   d2u
//   --- + --- = 0 + (force, not used)
//   dx2   dy2
// Can be solved by FFT also but this iterative method lets user control
// the accuracy of the solution. If all pixels are selected then this works
// like smooth with variable radius. Basically it just averages 4 adjacent
// pixels into the middle pixel :) Note however that one iteration pass uses
// uses 2 values per pixel already computed in that pass so it's a kind of
// cumulative smooth.
void SolveEquations(int **s, float *h, float *u, int Nodes, int maxiter)
  int i,c,dir=1,Node;
  float sum;
  for(i=0;i<maxiter;i++)
    {for(Node=(Nodes-1)*(1-dir)/2;dir*Node<=(Nodes-1)*(1+dir)/2;Node=Node+dir)
        { sum=h[Node];
          for(c=1;c<=s[Node][0];c++)
            sum=sum+u[s[Node][c]];
          u[Node]=0.25*sum;
      dir=-dir;  // toggle direction
// Prepares data for SolveEquations
void LevelConnector(int width,int height, int maxiter)
  int xo[4]={1,-1,0,0},yo[4]={0,0,1,-1};
  int c,Nodes=0,*NodeP,Node,PixN;
  int x,y,xt,yt,i,j,*Pos,**s;
  float *h,*u,Sel,PixV,k;
  // Count selected pixels
  for(y=0;y<height;y++)
    {for(x=0;x<width;x++)
       {if(GetSelValue(x, y) == SELECTED)
          Nodes++;
  u=(float *)malloc(Nodes*sizeof(float)); // This is the actual height data
  h=(float *)malloc(Nodes*sizeof(float)); // aux data for equations
  Pos=(int *)malloc(Nodes*sizeof(int));   // Stores pixel positions of nodes
  s=(int **)malloc(Nodes*sizeof(int *));  // aux data for equations
  // clear arrays
  for(Node=0;Node<Nodes;Node++)
    s[Node]=(int *)malloc(5*sizeof(int));
    if (s[Node] == NULL) {perror("memory error");exit(1);}
    for(j=0;j<5;j++)
      s[Node][j]=0;
    u[Node]=0;
    h[Node]=0;
    Pos[Node]=0;
  // Fill position table
  Node=0;PixN=0;
       {Sel=GetSelValue(x, y);
        if(Sel == SELECTED)
          {Pos[Node]=PixN;
           Node++;
        PixN++;
  // Make equations
  Node=0;PixN=0;
          {k=0;c=0;
	   for(i=0;i<4;i++)
             {yt=y+yo[i];
              xt=x+xo[i];
              if (yt == -1)      yt=height-1;
	      if (yt == height) yt=0;
	      if (xt == -1)      xt=width-1;
	      if (xt == width)   xt=0;
              hv=GetHeight(xt, yt);
              PixV=HVToFloat(hv);
              if(GetSelValue(xt, yt) != SELECTED)
                k=k+PixV;
              else
                {c++;
                 PixN=yt*width+xt;
	         NodeP=(int *)bsearch(&PixN,Pos,Nodes,sizeof(int),(fptr)compare);
                 if(NodeP == NULL)
                   {perror("error in bserch");
                    exit(1);
                 s[Node][c]=(int)(NodeP-Pos);
           hv=GetHeight(x, y);
           u[Node]=HVToFloat(hv);
	   h[Node]=k;
	   // h[Node]=k-force;  past experiment
	   s[Node][0]=c;
	   Node++;
  SolveEquations(s,h,u,Nodes,maxiter);
  free(h);
  // Write data in u[] back to hf
      free(s[Node]);
      hv=FloatToHV(u[Node]);
      x=Pos[Node]%width;
      y=Pos[Node]/width;
  free(s);
  free(Pos);
  free(u);
K.K.
Date: 12 Aug 2000 16:33:38
Message: <chrishuff-440A3B.15344512082000@news.povray.org>
In article <3995801A.AC206C81@kivisalo.net>, Kari Kivisalo
> numerical approximation using difference equations and iterations.
> This can be solved with FFT also but I don't yet know how. Should be
> easy enough to find: "solving poisson with fft". Numerical Recipes
> has nice code for 3D FFT which calculates the solution in-place
> saving memory.
Thanks...it looks like it will take a while to analyze this and convert
it to 3d, though. I guess it would help if I had some calculus...and
don't expect a FFT solving method from me. :-)
Date: 12 Aug 2000 17:23:51
Message: <3995c067@news.povray.org>
"Kari Kivisalo" <kar### [at] kivisalonet> wrote in message
news:3995801A.AC206C81@kivisalo.net...
solved
filter.
> rest of the app.
>   hv=GetHeight(x, y);
> file://def for the compare func used by bsearch
>   return(*a - *b);
> //   d2u   d2u
> //   dx2   dy2
works
uses
>   int i,c,dir=1,Node;
>   float sum;
>         { sum=h[Node];
>           u[Node]=0.25*sum;
>           Nodes++;
data
nodes
>   // clear arrays
>     for(j=0;j<5;j++)
>       s[Node][j]=0;
>     u[Node]=0;
>     h[Node]=0;
>     Pos[Node]=0;
>   Node=0;PixN=0;
>         if(Sel == SELECTED)
>           {Pos[Node]=PixN;
>            Node++;
>         PixN++;
>   // Make equations
>   Node=0;PixN=0;
>           {k=0;c=0;
>    for(i=0;i<4;i++)
>              {yt=y+yo[i];
>               xt=x+xo[i];
>               PixV=HVToFloat(hv);
>                 k=k+PixV;
>               else
>                 {c++;
>                  PixN=yt*width+xt;
>                  if(NodeP == NULL)
>                     exit(1);
>            hv=GetHeight(x, y);
>    h[Node]=k;
>    s[Node][0]=c;
>    Node++;
>   free(h);
>       free(s[Node]);
>       x=Pos[Node]%width;
>       y=Pos[Node]/width;
>   free(s);
>   free(Pos);
>   free(u);
> K.K.
   Aaaaaaaargh!!!  You've frightened the s**t out of me now
  Kari!!  Whats a man to do?? (Need new specs after that! Me 'eads gone all
dizzy!! ;o)
                                ~Steve~
    PS, how do I save an image as .jpg, *in POV-Ray*, to 'send' to you very
'NICE' people to perooooose over? Simple question, I know, but I'M sure that
you can handle it, Kari............thanx.
Date: 12 Aug 2000 17:45:09
Message: <chrishuff-CC5169.16461612082000@news.povray.org>
In article <3995c067@news.povray.org>, "25ct" <25c### [at] lineonenet> wrote:
> very 'NICE' people to perooooose over? Simple question, I know, but
> I'M sure that you can handle it, Kari............thanx.
You don't. You have to use an external program to convert an image
generated by POV(in PNG or TGA format, for example) to JPEG. The next
version may include JPEG *input*, but JPEG, as a "lossy" format, won't
be available for output.
