POV-Ray : Newsgroups : povray.general : Rotation with axis location specified? Server Time
15 Jan 2026 18:32:36 EST (-0500)
  Rotation with axis location specified? (Message 1 to 4 of 4)
Subject: Rotation with axis location specified?
Date: 16 Jul 2000 20:15:41
Message: <3972502A.6B8EC604@bigfoot.com>
Hi, I'm not sure I can describe this correctly, but here goes..
I have a complex CSG (a human arm) that I'd like to rotate
at the shoulder.  Unfortunately, the standard rotate command
will turn it at the center of the object, which moves the shoulder
way off beam, requiring painstaking translate experimentation to
get it back to where it should be.
Is there a macro or method for specifying where the rotation
axis should be for an object, rather than it using the object's
center?
I apologise if this is a naive question - I'm new to Povray.
Cheers,
-Andrew
Subject: Re: Rotation with axis location specified?
Date: 16 Jul 2000 21:00:06
Message: <39725AAE.8E240E52@erols.com>
> center?
So you want to rotate around a point other than the origin (which is
at <0,0,0>)?  Do it this way:
  translate -Center_of_Rotation
  rotate RotationVector
  translate Center_of_Rotation
Since rotation is always around the origin, to rotate around another
point, move stuff from that point to the origin, rotate it, and then
move it back.
It is generally easier to prevent this trouble by designing your objects
at the origin, rotating them, and then moving them to where you want
them.
Hope this helps,
John
ICQ: 46085459
Date: 16 Jul 2000 21:11:37
Message: <39725D45.F298BD4D@bigfoot.com>
Found solution in previous posts to this newsgroup.
Cheers,
-Andrew
Date: 16 Jul 2000 21:15:58
Message: <39725E4A.C75F851@bigfoot.com>
> > center?
> move it back.
> them.
Yes, that does help.  I've also just discovered your excellent
matrix page, which has the exact solution to the problem.
Many thanks,
-Andrew
