POV-Ray : Newsgroups : povray.general : Fire and water simulation Server Time
25 Apr 2026 21:55:26 EDT (-0400)
  Fire and water simulation (Message 1 to 4 of 4)
Subject: Fire and water simulation
Date: 25 Jun 2000 11:54:07
Message: <39562b1f@news.povray.org>
Hello!
I wonder how to make a realistic animation of fire in povray. I intend to do
a fire like a torch. I also wonder if anyone know how to do a realistic
fountain of upward-flowing water?
Greatful for answer.
Urano
Subject: Re: Fire and water simulation
Date: 25 Jun 2000 12:02:56
Message: <39562d30@news.povray.org>
news:39562b1f@news.povray.org...
"realistic" just isn't easy.  First of all, the water could be done very well
using Chris Colefax's Spray.inc which can be found at:
http://www.geocities.com/ccolefax/
The fire thing is something people approach differently imo.  I have a torch
flame for example but it isn't great and far from very realistic but that's
mostly because it's a subjective thing.  Fire can look various ways irl to
begin with.
But anyhow, the way I made the torch flame was to use a cylindrical media
which translated upward using clock.
Date: 25 Jun 2000 16:36:16
Message: <39566E57.AAD4F492@yahoo.com>
i haven't done this yet, but i had an idea about candle or torch flames
a while back.  blobs are made of spheres and cylinders.  the cylinders
don't have to have the same diameter at each end, i.e. you can make it a
cone.  i'm thinking that if a blob of a cone placed above a sphere were
made, then in animation:
1) the sphere is scaled slightly in the three directions,
2) while at the same time the base of the cylinder dances around inside
the sphere by means of slight translations in all directions, the top of
the cone always above it,
3) the strength of the blob interaction is fluctuated to give variety to
the size and shape of the flame,
4) the size of the cone's top radius is varied, to give a point
sometimes and soft tops other times,
5) the media inside changes scale in order to have the flame dissipate
at the edge of the blob at all times.
i don't recall which media type is the slowest (scattering, emmitting,
or the other), but a light source inside the flame that also dances with
the cone might work well with it.  i'm currently in the middle of two
other projects right now, and want to finish them first, otherwise i'd
try this out myself.  which ever method you choose, good luck.
> Hello!
> Urano
Date: 26 Jun 2000 20:38:18
Message: <chrishuff-5FAB36.19424926062000@news.povray.org>
> intend to do a fire like a torch. I also wonder if anyone know how to
> do a realistic fountain of upward-flowing water?
Someone else has mentioned the Liquid Spray include file already, it
should do what you want.
For fire...I usually use a media object with a spherical density, and
adjust the color_map, turbulence, and scale to fit the flame I want.
Could you be more specific about the type of flame you want?
