![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Could anyone tell me if there is a limit to the resolution of images you
create with povray? could i for instance create an image 10240x7680 ? do
different file formats only support up to a maximum resolution?
Thanx
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Theoretically YES but practically NO - limited by RAM - for image bytes &
virtual mem & when I tried it with a simple scene POV took forever to create
light buffers.
Pabs
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thanx
> John
I don't know about pov, but file formats are limited by width and height
data fields:
TGA : 16 Bit (65535x65535)
PNG : 32 Bit (... ;-)
Thats probably far away from usual values
(24 Bit TGA uncompressed 65535x65535 would be 12 GB !)
HTH, Christoph
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
[Christoph Hormann <chr### [at] gmx de>]
But on some OSes (like Windows) your image would be limited by the
filesystem.
Never attribute to malice that which
can be adequately explained by stupidity.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> filesystem.
I don't understand. What is the limiting factor? (besides FAT 16 maximum
partition size)
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If I'm not mistaken, an A1 print at 1440 DPI would be 33,675 by 47,678 points.
Granted, this is an extreme example - but even a 'mere' A4 print would be 11,904
by 16,837 points.
So these numbers are not quite as imossible as they might seem. Working with
images intended for high-quality printing is a royal pain, to say the least.
Margus Ramst
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3946EA34.A4C0D047@peak.edu.ee> , Margus Ramst
>> filesystem.
> partition size)
There are still a lot of filesystems that have a 2 GB or 4 GB file size
limit. Additionally, a lot of applications make assumptions about certain
system file IO functions, i.e. when seeking inside a file and using long or
unsigned long (which is most likely 32 bit on common platforms today).
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> by 16,837 points.
Normally, you do not need a full printer resolution image for printing,
because the printer has to do rastering anyway, even though some people
recommend exactly that.
AFAIK a high quality offset print for example for illustrated books has
about 100 to 300 dpi.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
