![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am trying to make an easier way to access the POV-RAY help. ( ie : CHM
help file)
Just as a trial I have begun to use frames and for the time being, the
working links are those of 'Camera' and some of 'Lights'.
By the way, if someone could tell me how to get rid of the cookies which
my IAP inserted in the HTML scripts......
It is best viewed at 1024 x 768 with either Netscape 4.7 or IE 5 (even
though there is no javascript yet).
It can be found at my homepage :
http://perso.club-internet.fr/ffjhenon
I am realizing that even with copy and paste, there is a huge amount of
work ahead.
Tell me what you think and most important your suggestions.
I started this after a visist on Popeney's site on javascript :
http://www.calpoly.edu/~dpopeney/javascript.html
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The format is helpful, but I would make the syntax frame smaller than the
text frame. The amount of information in the text frame warrants a larger
screen space. You could probably shrink the left hand frame a bit as well.
As far as the HTML, you don't need to use an map for an image if the entire
image is the link. I'm not sure why sites do this but regular HTML can
handle an image as a link without all that map stuff. It just makes the page
larger and more complicatied.
Josh
> help file)
> work ahead.
Josh English
eng### [at] spiritone com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Josh English" <eng### [at] spiritone com> wrote in message
news:3936AD45.7F28B8CA@spiritone.com...
| text frame.
I didn't see the SYNTAX frame until the IE window was maximized. The TEXT
frame was occupying the entire right side, without any scrollbars either. No
idea why. Going to Camera/Syntax doesn't show anything then until the window
is maxed :-(
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I will increase the text frame so that it will take 50 % of the right window.
The link stuff is not that complicated, but yes I think I will make the link on
the entire camera (&light) image.
Cheers.
> Josh
> > help file)
> > work ahead.
> Josh English
> "May your hopes, dreams, and plans not be destroyed by a few zeros."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> | text frame.
> is maxed :-(
I think that's because I sized the frame in pixels and not in percent. I'll
correct that.
Besides, the page is best viewed at 1024 x 768. I'll give it a try at 800 x 600.
> Bob
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
