POV-Ray : Newsgroups : povray.general : #declaring warps. Server Time
27 May 2026 03:49:34 EDT (-0400)
  #declaring warps. (Message 1 to 10 of 12)
Subject: #declaring warps.
Date: 27 May 2000 15:13:30
Message: <39301e5a@news.povray.org>
Am I doing it wrongly, or is it impossible to #declare a warp? Povray even
_crashes_ when I try to get around by using a #macro.
I tried this:
#macro Foo
turbulence 0.4
And later:
object
    something_nice_as_well
        marble warp { Foo }
This causes Povray to crash. I also tried to wrap the warp-statement as well
into the macroa dn just calling the macro to place it like this:
pigment { marble Foo }
But Povray didn't like a warp in a macro.
Anyone who can explain?
TIA,
Simen Kvaal.
Subject: Re: #declaring warps.
Date: 27 May 2000 15:48:45
Message: <3930269d@news.povray.org>
Simen Kvaal <sim### [at] studentmatnatuiono> wrote:
: Am I doing it wrongly, or is it impossible to #declare a warp?
  Yes, I'm impossible to #declare.
Date: 27 May 2000 20:11:51
Message: <3930566E.37A530DB@peak.edu.ee>
I don't think you can declare a warp. However I have no problems using it in a
macro:
#macro Foo()
    turbulence .2
sphere{
    0,1
    pigment{checker rgb 1, rgb 0 Foo()}
Works just like expected, both in regular 3.1g and MegaPov 0.5 (Windows). What
version are you using?
Margus Ramst
Date: 28 May 2000 01:19:33
Message: <3930ac65$1@news.povray.org>
Simen Kvaal wrote in message <39301e5a@news.povray.org>...
>object
>    pigment {
>        marble warp { Foo }
You appear to have forgotten the parentheses in your macro call.  Try this:
object
        marble warp { Foo() }
Mark
Date: 28 May 2000 02:20:31
Message: <3930baaf@news.povray.org>
Maybe you already realize this, cannot declare a keyword for use later.
#declare Turb=turbulence 0.4
would need to be retrieved as:
warp {turbulence Turb}  anyhow.  If that's possible to begin with anyway in a warp, I
didn't check.
"Simen Kvaal" <sim### [at] studentmatnatuiono> wrote in message
news:39301e5a@news.povray.org...
| I tried this:
| #macro Foo
| turbulence 0.4
| #end
| And later:
| object
|     pigment {
|         marble warp { Foo }
| TIA,
| Simen Kvaal.
Date: 28 May 2000 05:02:58
Message: <3930e0c2$1@news.povray.org>
Ah! That might be the problem. But seriously, Povray shouldn't _crash_ on
me, performing "an illegal operation", when stumbling into erroneus
scripting ...
I also find it somewhat inconsistent not to be able to #declare a warp;
what's the logical difference between a warp-block and a, say,
pigment-block? I have to say it would be very convenient to be able to do
so.
Simen.
Date: 28 May 2000 05:07:30
Message: <3930e1d2@news.povray.org>
Oh no! I should have expected that! :-) But I _can_ declare you:
for example:
#declare Warp =
    checker
    color rgb <1.0, 0.77, 0.94> // yuckish pink color for my dear Warp. ;-)
    color rgb <1.0, 0.32, 0.83> // saturate the pink, yuckish color a bit
*chuckle*
Simen.
Date: 28 May 2000 16:20:28
Message: <90e2jsgpdgieb0odk3ka4mc35ba448jvtt@4ax.com>
On Sat, 27 May 2000 21:13:27 +0200, "Simen Kvaal"
Correct me if I'm wrong but a warp is a kind of transform, so have you
tried declaring it as such?
Peter Popov ICQ : 15002700
Date: 28 May 2000 21:02:44
Message: <3931B3E4.E08B3880@peak.edu.ee>
No, transform does not take a warp; it only takes general transformations
(translate, rotate, scale, matrix).
Margus Ramst
Date: 29 May 2000 09:22:43
Message: <39326f23@news.povray.org>
I would prefer:
pigment { checker Blue, White }
