POV-Ray : Newsgroups : povray.general : Reflection_map Server Time
31 Oct 2024 06:04:28 EDT (-0400)
  Reflection_map (Message 1 to 6 of 6)
Subject: Reflection_map
Date: 9 May 2000 17:57:59
Message: <391882CD.F4B60350@club-internet.fr>
Is there a way to do "reflection_map" in POV ?
It's a feature seen in Lightwave 5.6 : You stick a B&W image to an
object, only the white areas will be reflective, while the dark parts
will not reflect anything. Just like a bump_map, but with reflection.
Is there someway to work around this ?
Thanks
Subject: Re: Reflection_map
Date: 9 May 2000 19:00:38
Message: <r06hhs0l86iuvjgqjfjgk2kefkvn9rf5fr@4ax.com>
Yes, using a texture map of identical textures with the only
difference being the reflection amount.
Peter Popov ICQ : 15002700
Date: 9 May 2000 22:31:15
Message: <chrishuff_99-5D019C.21343509052000@news.povray.org>
This has come up before, I think it was decided that a "finish_map"
feature would be more useful, but nobody has implemented it yet. In the
mean time, use material_map(or, if you have MegaPOV, you can use
texture_map with an image pattern).
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 10 May 2000 03:51:27
Message: <39191484.145EC680@inapg.inra.fr>
There an example of code here that gives variable reflections using
image_pattern and texture_map:
http://www.inapg.inra.fr/dsa/temp/makingof6.htm
G
Date: 10 May 2000 04:08:57
Message: <3919190D.F2DB0BF2@umh.ac.be>
Yes but with texture_map you cannot control precisely the form
of your map. One can try material_map. So you take your B&W
images you put the same texture for the black and white index
but with different finish.
Fabian.
> Personal e-mail : pet### [at] usanet
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 10 May 2000 17:51:28
Message: <3919D99E.4B993335@club-internet.fr>
I wiil give a try with your code.
Thanks a lot.
Does anyone know what new features will be incorporated for the very expected
POV 3.5 ? Ken ?
> G
