POV-Ray : Newsgroups : povray.general : POV-CSDL (or Java Binding?) Server Time
21 Jun 2026 22:13:47 EDT (-0400)
  POV-CSDL (or Java Binding?) (Message 1 to 10 of 92)
Subject: POV-CSDL (or Java Binding?)
Date: 12 Mar 2000 07:37:31
Message: <38cb8f8b@news.povray.org>
Hi!
I moved this here from povray.off-topic, since it was getting more and
more on-topic (and also being related to the much discussed "The
Language of POV-Ray" thread).
Chris Huff made the suggestion of creating some sort of POV-CSDL ("C
like Scene Description Language") in the thread "Programming in
Highshool" in off-topic. That would be a language based on C or C++ to
be used to create POV-scenes. The scene would then be run through a sort
of "compiler" to create a "real" POV-Script from it.
The idea was, that only the "programmers" among us would want to write
CSDL scripts (for example for complex includes/plug-ins) and that normal
users could simply include the produced "normal" POV-Script into their
scenes, not having to worry about the CSDL at all - they could simply
ignore that part.
A CSDL plug-in would thus be published as two sources: A CSDL source and
a POV-Script source. "Programmers" could use the CSDL source to modify
the plugin to their own needs, and "Users" could use the POV-Script
(compiled from the CSDL) to use the plug-in in their scenes.
Sounds like a good compromise to me, having all the arguments from "The
Language of POV-Ray" in mind.
However, I think the approach can be made a lot easier, by not creating
a new language that would need a parser and compiler, but by simply
creating a binding in an already existing language. In the original
thread someone pointed out the efforts to create a Perl binding.
Personally I don't like Perl ;) but this whole thing reminded me of a
topic I brought up a while ago: A Java binding of POV.
Back then I realized that this would be a fully academic exercise, since
it was clear that no-one would actually program scenes in a POV-Java
binding.
But under the new light of using the binding to create
"high-level-language" plugins, that can still be used by "normal" users
without the need to know anything about the binding, this approach
sounds again interesting (at least to me :)
Here is how it would work:
A number of packages (class libraries) would be written in Java to
support the POV-objects. A "programmer" could then use these packages to
program POV scripts (with focus on plugins, not on full scenes) directly
in Java, in a manner intuitive to programmers.
The resulting Java program would, if compiled and run, create a standard
POV-Script plugin which could be included into any POV-Scene, and which
would contain any macro and object created in the Java-Script.
The programmer could publish both the Java code (to make his plugin
modifiable by other programmers) and the resulting POV-Scene (to make
the plugin usable by "normal" users) (usually both would be published
together).
The advantage over the CSDL approach would (in my eyes) be that no "new"
language is needed. Why create a parser and compiler, if it is already
there, for example in the Java parser, compiler and runtime environment?
Chris, what do you think?
Others?
Johannes.
Subject: Re: POV-CSDL (or Java Binding?)
Date: 12 Mar 2000 09:01:57
Message: <38cba355@news.povray.org>
Well, I personally don't like Java.
  A C++-binding would be more pleasant to me.
Date: 12 Mar 2000 09:07:12
Message: <38CBA3C0.3254B378@pacbell.net>
It would have to be in Qbasic or I wouldn't use it.
Date: 12 Mar 2000 09:32:05
Message: <38cbaa65$1@news.povray.org>
"Nieminen Juha" <war### [at] sarakerttunencstutfi> wrote in message
news:38cba355@news.povray.org...
    Just from a non-programmers point of view, I see as many C++ users as
Java around here, and from what I have been told is that Java can be seen as
a preparatory language for C++.
    Therefore, the Java guys should be able to use C++ with a little extra
work, and then both could have the advanced functionality of C++...
    Just repeating what I have heard.
Date: 12 Mar 2000 09:42:17
Message: <38cbacc9@news.povray.org>
I have thought about that too. (ISO) C++ would certainly be more
platform independent than Java, especially since what we want is source
code level independency, not binary level independency (which is Java's
strong feature).
Johannes.
Warp -*/
Date: 12 Mar 2000 10:51:13
Message: <8EF5AE4F2seed7@204.213.191.228>
>binding.
What is a binding?
Will it make it possible for a Java (or Perl) program to interact with a
scene during parsing? Kind of a macro being executed outside POV and its
result being used in the scene again (without writing/reading a file).
#binding {
  perl,            //language
  "GrowTree.pl"    //file
  Age              //Data needed by GrowTree.pl
  Shadowside
  Oak
This sounds more like a program that can output a POV-file but not interact
with POV.
Ingo
Date: 12 Mar 2000 11:06:23
Message: <38CBBF97.2956477D@pacbell.net>
> with POV.
I think the idea here is to create a text based modelling/programming
environment that uses high level programming features and will output
a standard POV-Ray scene file when done. The resulting scene file will
comply with current versions of POV-Ray syntax and proceedures. I am
assuming that when the high level progamming code is parsed/compiled
it will be automagically translated into native Pov syntax easing the
development of complex include files and what not but I am still unclear
about how this will be accomplished.
Date: 12 Mar 2000 11:28:21
Message: <chrishuff_99-18E4E1.11301012032000@news.povray.org>
In article <38cb8f8b@news.povray.org>, "Johannes Hubert"
> ignore that part.
This is a good description of what I had in mind, except that it
wouldn't be exclusively for plugin development, and I am hoping the
non-programmers would also want to develop scenes in it.
> together).
The Java language isn't designed for scene description. CSDL could be
used for scene description as well as plugin development, and would have
the advantage of being designed for the purpose of describing objects in
3D space. People who want to make scenes but want a cleaner, more
flexible language than POV-Script could use CSDL.
ANSI/ISO C++ could be better, since it is more platform independant and
has things like operator overloading which would make things like vector
manipulation easier, but then people who don't know C++ would have to
learn it. And the fact that it would require a C++ compiler would drive
many away, more people would be willing to use a pre-compiled utility,
especially if it includes an editor and a way to access POV on their
platform.
Also, CSDL would be a much simpler language than C++/Java, probably
without things like class types(you could attach variables and functions
to specific objects, and make copies of those objects, though.). It
would be object-oriented, but in a different way from C++ or Java, it
would be oriented toward specific objects and their "children" instead
of kinds of objects. It's variables, functions, expressions, loops and
conditionals would use a C-like syntax, but some of the C types would be
eliminated, pointers would behave themselves, and there would be
additional types like object, vector, pigment, texture... It would be
more strongly typed than POV-Script, but you could still do things like
make a pigment into a texture and a float or int into a vector.
Component parts of objects(like transform, texture, other flags and
properties) would be accessible with dot notation.(I think the ->
notation for pointers to objects should probably be left out)
It wouldn't be an extended C/C++/Java with additions for making scenes,
it would be a new, cleanly designed language based on those languages,
without all the "dirt" that POV-Script has accumulated over time, and
designed with the purpose of describing scenes and developing plugins.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 12 Mar 2000 11:40:22
Message: <chrishuff_99-5BCFBA.11421312032000@news.povray.org>
In article <38CBA3C0.3254B378@pacbell.net>, lin### [at] povrayorg
Would you use it even if it *was* in Qbasic? :-)
Chris Huff
Date: 12 Mar 2000 11:46:30
Message: <38CBC8F6.8B481E2A@pacbell.net>
Maybe. I have some POV-Ray object building files in .bas format that
I have never taken the time to figure out how to convert to .pov
syntax. If something could parse and convert them for me I would use
it.
A thought... Some of these files query the user for parameters during
the program run time. If added to Pov it sure would reduce the number
of predeclared variables needed in the scene.
