POV-Ray : Newsgroups : povray.general : Lathe prism? Server Time
10 Aug 2024 15:20:43 EDT (-0400)
  Lathe prism? (Message 1 to 5 of 5)
Subject: Lathe prism?
Date: 14 Dec 1999 15:33:12
Message: <3856a988@news.povray.org>
I would like to define a curve which I can sweep out around the y-axis,
almost like a lathe object. However, I'd also like to change the curve at
various angles about the Y-axis. I don't believe this capability currently
exists. Might this be a future capability, or does a patch add this?
Jon
Subject: Re: Lathe prism?
Date: 14 Dec 1999 16:49:43
Message: <chrishuff_99-95D56E.16501414121999@news.povray.org>
In article <3856a988@news.povray.org>, "Jon S. Berndt" <jsb### [at] hal-pcorg>
Hmm, using a 3d spline(with angle for the 3rd dimension) to control the
points of the spline-interesting idea. I think it might be very
difficult to write this as a patch, though.
However, it would be possible to write a macro to generate a mesh, using
one of the spline patches would make that a lot easier.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 14 Dec 1999 16:52:59
Message: <3856bc3b@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote in message news:chrishuff_99-
at
currently
For now, I will probably create the surface in either smooth_triangle
sections, or a conglomeration of panels, or something...
I'm still thinking about it.
Jon
Date: 14 Dec 1999 21:48:55
Message: <38570197@news.povray.org>
Perhaps Daniele Varrazzo's Striscia can help
(http://members.xoom.com/dvarrazzo) with this sort of extrusion modelling?
Otherwise bicubic patches offer the advantage of small file sizes and high
quality, whether hand coded or created using sPatch/Moray, etc.
Date: 15 Dec 1999 08:25:49
Message: <385796dd@news.povray.org>
As well as the advantage of being intuitive to specify parameters for by hand,
if you use bezier splines for the curves that define the object.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
