POV-Ray : Newsgroups : povray.general : Background Image? Server Time
10 Aug 2024 17:22:26 EDT (-0400)
  Background Image? (Message 1 to 6 of 6)
Subject: Background Image?
Date: 1 Dec 1999 05:51:24
Message: <3844FE00.35C1FE97@jpberlin.de>
Hi!
Is there any possibility to render images with a background image instead
of a background color?
Is there any patch for it?
Gevatter
Subject: Re: Background Image?
Date: 1 Dec 1999 06:21:06
Message: <38450426.EFE2C6E1@pacbell.net>
Gev### [at] jpberlinde wrote:
> Hi!
> Gevatter
You could simply add a plane with an image map attached to it.
It is also possible to use an image map with the sky_sphere
but it is distorted by the shape of the feature.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 1 Dec 1999 10:43:50
Message: <38454236@news.povray.org>
You can use +FN +UA for outputting a 24 bit .png-image with an
alpha-channel. That way, you can easily mask away the background and add an
image in, say, PaintShop pro.
Simen.
Gev### [at] jpberlinde skrev i meldingen
<3844FE00.35C1FE97@jpberlin.de>...
>Hi!
>Gevatter
Date: 1 Dec 1999 11:08:41
Message: <3845485B.B1453203@jpberlin.de>
Nope, that doesn't work correctly (perhaps a bug?):
I've medias in my scene: As you know, they are colored <rgbt 1>.
If a ray hits a media object, there is a hole on this place in the
alpha-channel, !even if there's an object behind the media! It's 100%
transparent.
Hm. Is my problem clear? I'n not good in expressing myself in english...
Gevatter
Date: 2 Dec 1999 15:15:36
Message: <3846D363.A214661D@spiritone.com>
Aha! I posted an incorrect solution earlier today, but I've apparently fixed
it. I will defineitly add this to my Camera Effects stuff.
Here is the code.
#local CamLook = <0,0,3>; // Camera's Look_at
#local CamLoc = <0,0.5,-6>; //where the camera's location is
#local cam_z = 2; //the amount of camera zoom you want
#local back_dist = 100; // how far away the background is
#local cam_a = 4/3; // camera aspect ratio
#local cam_s = <0,1,0>; // camera sky vectoy
#local cam_d = vnormalize(CamLook-CamLoc);
#local cam_r = vnormalize(vcross(cam_s,cam_d));
#local cam_u = vnormalize(vcross(cam_d,cam_r)); // camera up vector
#local cam_dir = cam_d * cam_z;
#local cam_right = cam_r * cam_a;
#declare fz = vlength(cam_dir);
#declare fx = vlength(cam_right)/2;
#declare fy = vlength(cam_u)/2;
  location CamLoc
  up cam_u
  right cam_r * cam_a
  direction (cam_d * cam_z)
box { <0,0,0> <1,1,0.1>
      pigment { image_map { png "background.png"
                                             map_type 0
                                             interpolate 2 } }
      translate <-0.5,-0.5,0>
      scale 2*<fx,fy,0.5>
      translate fz*z
      scale back_dist
      #local nz = vnormalize(CamLook-CamLoc);
      #local nx = vnormalize(vcross(cam_s,nz));
      #local ny = vcross(nz,nx);
      matrix <nx.x,nx.y,nx.z,
               ny.x,ny.y,ny.z,
              nz.x,nz.y,nz.z,
              CamLoc.x,CamLoc.y,CamLoc.z> }
> Hi!
> Gevatter
Josh English
eng### [at] spiritonecom
ICQ: 1946299
"Stress is when you wake up screaming and realize you haven't fallen asleep
yet."
Date: 2 Dec 1999 16:54:29
Message: <3846ea95@news.povray.org>
>Hi!
>Gevatter
I think you could use my Illusion Include
File together with a sky_sphere.
Illusion.inc is available from
http://rsj.mobilixnet.dk
Greetings,
Rune
Updated November 19: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
