POV-Ray : Newsgroups : povray.general : Color Passing in #macro Server Time
16 Mar 2026 15:07:31 EDT (-0400)
  Color Passing in #macro (Message 1 to 10 of 16)
Subject: Color Passing in #macro
Date: 26 Nov 1999 06:42:28
Message: <383E7213.7DF63B99@gci.net>
I just ran into something strange. While trying to
pass a color vector through a macro, the color changed!
The code is simple
#include "Colors.inc"  #include "finish.inc"
#declare CapColor=<1,0,0,0,0>;
#macro Cap(Color)
difference
	union	{
		cylinder{<0,0,0>,<0,.0889,0>,.17}
		cylinder{<0,.0889,0>,<0,.1333,0>,.2}
		cylinder{0,y*.0667,.12 translate y*.1333}
	pigment{ rgbft Color} //Will promote to a 5 component vector
camera		{ location <0,5,-5> look_at 0 angle 40 }
light_source	{ 0,White translate -z*40 rotate <30,-10,0> }
background	{ White}
object		{ Cap(CapColor) }
If I #declare CapColor= a three or four component vector, it works fine.
But as a five component vector something doesn't work so well.
Can anyone give some insight on this?
Subject: Re: Color Passing in #macro
Date: 26 Nov 1999 06:59:13
Message: <383e7611@news.povray.org>
It certainly looks like a bug. I don't know of any way of printing the
values of the vector when it has five components so I can't see what's
happening. There seems to be no way to access the 5th component of a vector
and #write doesn't work for 5-dimensional vectors for some strange reason.
  5-dimensional vectors are obviously handled differently from 4 or less
dimensinal vectors, and perhaps the bug is related to that.
Date: 26 Nov 1999 11:01:57
Message: <383eaef5@news.povray.org>
In article <383e7611@news.povray.org> , Nieminen Juha
No, you can just treat it as a color:
#macro Cap(Color)
difference
 union {
 #warning "Vector <"
 #warning str(Color.red,0,3)
 #warning ", "
 #warning str(Color.green,0,3)
 #warning ", "
 #warning str(Color.blue,0,3)
 #warning ", "
 #warning str(Color.filter,0,3)
 #warning ", "
 #warning str(Color.transmit,0,3)
 #warning "> "
light_source { 0,rgb 0 translate -z*40 rotate <30,-10,0> }
background { rgb 0}
     Thorsten
e-mail: tho### [at] trfde
Date: 26 Nov 1999 11:03:09
Message: <383eaf3d@news.povray.org>
In article <383E7213.7DF63B99@gci.net> , "mr.art" <mr.### [at] gcinet> wrote:
I can't reproduce it. My output is as expected (see my other post). Which
version of POV-Ray are you using?
    Thorsten
Date: 26 Nov 1999 13:26:52
Message: <383ED0CB.BCDD618A@gci.net>
I have used the Official version 3.1g, the Superpatch, and UVPOV 6.1a
All with the same results.
Printing the vector information like you suggested in your other
post gave these results vector<0.000,1.875,0.000,0.000,0.000>
for the color vector <1.000,0.000,0.000,0.000,0.000>
I am using Win98, PII 400,128meg Ram
>     Thorsten
Subject: more data
Date: 26 Nov 1999 13:56:58
Message: <383ED7D9.84C18138@gci.net>
Here is more data to ponder:
#declare CapColor=<1,1,0,0>; outside the macro becomes <1,1,0,0> inside
But
#declare CapColor=<1,1,0,0,0>; becomes <0,1.875,0,1.875,0> inside
>     Thorsten
Subject: Re: more data
Date: 26 Nov 1999 14:22:52
Message: <383EDDEB.174731B4@gci.net>
Try this for simplest code :
// #declare CapColor= <1,0,0,0,0>;
   #declare CapColor= color <1,0,0,0,0>;
#warning "Vector <" 	#warning str(CapColor.red     ,0,4)
#warning ", "		#warning str(CapColor.green   ,0,4)
#warning ", "		#warning str(CapColor.blue    ,0,4)
#warning ", "		#warning str(CapColor.filter  ,0,4)
#warning ", "		#warning str(CapColor.transmit,0,4)
#warning "> "
sphere{0,0 pigment{color 0}}// keeps the error messages away
uncomment one or the other of the #declare statements.
#declare CapColor= color <1,0,0,0,0>; gives correct results
#declare CapColor= <1,0,0,0,0>; doesn't
So the problem seems to be not in the #macro stuff at all
but in the assignment process.
> But
Date: 26 Nov 1999 16:41:01
Message: <383efe6d@news.povray.org>
In article <383EDDEB.174731B4@gci.net> , "mr.art" <mr.### [at] gcinet> wrote:
Yes, I can now verify your problem. It is a bug in the source code. A
detailed bug report has been posted to povray.bugreports.
     Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 26 Nov 1999 17:31:33
Message: <383F0A25.7E61D666@gci.net>
Thank you. I know that the easy workaround
is to use the keyword color in front of the vector.
But if someone had tried to 5d vectors for another
use, it could mess them up some. So, once again,
thank you.
Mr. Art
>      Thorsten
> Thorsten Froehlich
Date: 26 Nov 1999 18:23:16
Message: <5f5u3ssmp8f370e8qi7to6rsl0ua1u5ff1@4ax.com>
On Fri, 26 Nov 1999 15:40:53 -0600, "Thorsten Froehlich"
  Thank you for posting the fix, Thorsten.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
