POV-Ray : Newsgroups : povray.general : AVI compression; which? Server Time
23 Jun 2026 01:48:24 EDT (-0400)
  AVI compression; which? (Message 1 to 10 of 12)
Subject: AVI compression; which?
Date: 21 Nov 1999 09:14:15
Message: <3837fe37@news.povray.org>
My video editor has the following compression methods for AVI's; which is
generally useful in the p.b.a.-group? I am not sure that the one I used in
my first post is commonly used (MP4 V2):
- Cinepak Codec by Radius
- Intel Indeo Video 4.3
- Intel Indeo Video R3.2
- Microsoft Video 1
- Microsoft RLE
- Microsoft H.263 Video Codec
- Indeo Video 5.04
- Microsoft MPEG-4 Video Codec V1
- Microsoft MPEG-4 Video Codec V2
Your comments will be appreciated,
Sander
http://www.amtechnical.com/jeff/rose.html
Subject: Re: AVI compression; which?
Date: 21 Nov 1999 09:35:17
Message: <383802D2.5698732E@pacbell.net>
> - Microsoft Video 1
> - Microsoft RLE
Just about everyone should have the first 3 above and most will have the
last two as well. The others you have listed I do not have on my system.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 21 Nov 1999 15:02:05
Message: <38384fbd@news.povray.org>
I would go with H.263 for my personal use (but I normally just use
uncompressed AVI and then MPG them). I suggest you go with the latest Indeo.
Date: 21 Nov 1999 15:53:55
Message: <hls4OBDOmxDLlNCr+fiRnCFdIbHd@4ax.com>
On Sun, 21 Nov 1999 15:14:15 +0100, "Sander" <san### [at] the-internet>
>- Microsoft Video 1
>- Microsoft RLE
>- Indeo Video 5.04
>Sander
Of what you have installed, I'd use Indeo 5.04 (Codec ID "IV50") at
setings Quality:9000 and bytes/sec 32768 or 65536
Peter Popov
ICQ: 15002700
Date: 21 Nov 1999 21:23:15
Message: <3838a913@news.povray.org>
This is odd because I don't have either of those two Mpeg-4 codecs showing
here and yet something did download to play that file at p.b.a.  Wonder why
I can't list it here?  I've restarted computer since then.  Well, I know
it's there anyhow.
I checked all my Avi codecs against each other once for quality and
filesize, unfortunately I didn't take note of the results, think it was
Indeo 5.* which came up best of what I had at the time (it's v. 5.06 now),
so like Peter says that might be good and others should typically have it
too.  Thing is, I don't know if a version change alone messes up backward
compatibility or not.  I also have the Indeo interactive codec which I never
use because it seems others don't usually have that at all.
It's not going to be a sure thing anyhow.
Sander <san### [at] the-internet> wrote in message
news:3837fe37@news.povray.org...
> - Microsoft Video 1
> - Microsoft RLE
> - Indeo Video 5.04
> Sander
Date: 22 Nov 1999 08:46:49
Message: <3839489A.F450F237@my-dejanews.com>
Answer : none
MPG!
Date: 22 Nov 1999 08:50:31
Message: <383949D6.BC4E718B@pacbell.net>
"Greg M. Johnson" wrote:
> Answer : none
> MPG!
That is kind of a moot point. The codecs can be used in either animation
file format.
Date: 22 Nov 1999 16:38:24
Message: <3839b7d0@news.povray.org>
And how do you MPG them? I am such a layman..
Sander
TonyB <ben### [at] panamaphoenixnet> schreef in berichtnieuws
38384fbd@news.povray.org...
Indeo.
Date: 22 Nov 1999 17:06:55
Message: <3839BE13.997C05EC@pacbell.net>
> Sander
I think what Tony was implying is that you create an AVI then convert
that to an Mpeg movie. I don't know what if any advantage there is in
a two step process but he may be able to enlighten us on that subject.
Look around here http://www.povray.org/links/3D_Animation_Utilities/
for tools to convert from avi2mpg or to make mpeg files directly from
you images.
Date: 22 Nov 1999 17:50:23
Message: <3839C8FC.521E3B0A@merlin.net.au>
> > Answer : none
> > MPG!
> file format.
But if you're making an MPEG animation why wrap it up in an AVI?
Cheers, PoD.
