POV-Ray : Newsgroups : povray.general : Framed? Server Time
16 Jan 2026 19:12:38 EST (-0500)
  Framed? (Message 1 to 4 of 4)
Subject: Framed?
Date: 7 Nov 1999 21:34:47
Message: <382636A6.CCC7402C@gci.net>
Is there a quick/easy/intuitive way to assign a variable
the frame number that is being work on in an
animation? I would like on work on a few things
by frame count.
Any ideas?
Mr. Art
Subject: Re: Framed?
Date: 7 Nov 1999 22:02:02
Message: <38263d2a@news.povray.org>
>by frame count.
>Any ideas?
Yes.
#declare FrameNumber = clock/clock_delta;
Date: 8 Nov 1999 09:03:20
Message: <3826d828@news.povray.org>
Assuming your clock starts at zero and the first frame is numbered
zero, this is correct.  The more general formula is
#declare Initial_Clock=(whatever is in your INI file);
#declare Initial_Frame=(whatever is in your INI file);
#declare FrameNumber = (clock-Initial_Clock)/clock_delta + Initial_Frame;
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 8 Nov 1999 11:18:46
Message: <3826f7e6@news.povray.org>
Nathan has added an ini_option command to set an ini option from the pov
code.
  How about a reverse operation, ie. functions that return some values set
in the ini file (or wherever)? This way you could type:
#declare Initial_Clock = initial_clock();
or something like that.
