POV-Ray : Newsgroups : povray.general : Graphics Primitives in POVRay ? Server Time
27 Mar 2026 10:45:49 EDT (-0400)
  Graphics Primitives in POVRay ? (Message 1 to 2 of 2)
Subject: Graphics Primitives in POVRay ?
Date: 7 Nov 1999 17:48:28
Message: <382601bc@news.povray.org>
I want to insert some graphics primitives like lines, text etc. into
my rendering. I want to use especially text for documentation purpose (show
names of dedicated elements etc.).
However if I put text as text objects into my rendering (rotating and
scaling it
in that way that the normal vector of the text points torwards the camera,
to get an undistorted view of the text), POVRay slows down considerabely.
Are there any possibilities to speed up the rendering process by saying,
well
the text should pasted like a label into the picture after the picture is
raytraced?
The same problem occurs if I want use other graphics primitives like lines
to point on a special element in the rendering. I can use cylinders, thats
clear,
but this also slows down the rendering process when using many cylinders....
Using lines which are not rendered, just pasted into the picture would be
fine.
Rainer
Subject: Re: Graphics Primitives in POVRay ?
Date: 7 Nov 1999 21:55:03
Message: <tTkmOA+=z+bBIAc8zomaM6iAR5U2@4ax.com>
On Sun, 7 Nov 1999 23:49:35 +0100, "Rainer Minixhofer"
>scaling it in that way that the normal vector of the text points torwards
>the camera, to get an undistorted view of the text), POVRay slows down
>considerabely.
>clear, but this also slows down the rendering process
  That's why they call it ray tracing, Rainer :) If you really want to speed
things up, and post-processing doesn't matter to you, I would just use a
third party application like Paint Shop Pro (depending on your platform) to
apply text and lines. It is possible to create an image map with text and
lines and apply them to objects that can be positioned where you want them
to be but post-processing would be easier.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
