POV-Ray : Newsgroups : povray.general : Simple trick for getting different random numbers in each render Server Time
29 Nov 2025 21:36:00 EST (-0500)
  Simple trick for getting different random numbers in each render (Message 1 to 10 of 21)
Subject: Simple trick for getting different random numbers in each render
Date: 30 Oct 1999 04:30:12
Message: <381aac94@news.povray.org>
People continously are asking for a way for getting different random numbers
from render to render.
  Well, the solution to this is so simple that I'm ashamed of not having
discovered it until now.
  Add this at the beginning of your .pov file:
#if(file_exists("seed.dat"))
  #fopen ifile "seed.dat" read
  #read(ifile,R)
  #fclose ifile
  #declare Seed=seed(R);
#else
  #declare Seed=seed(0);
  Then use rand(Seed) in your pov code.
  Then add this at the end of your .pov file:
#fopen ofile "seed.dat" write
#write(ofile,int(rand(Seed)*1000000))
#fclose ofile
  It's that simple. Stupid me.
Subject: Re: Simple trick for getting different random numbers in each render
Date: 30 Oct 1999 05:14:51
Message: <381AB6D3.676EC919@pacbell.net>
>   #read(ifile,R)
>   #fclose ifile
> #else
> #end
> #fclose ofile
Which part of the above allows for a new random number each time ?
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 30 Oct 1999 05:22:24
Message: <381ab8d0@news.povray.org>
Using a random of a already random seed() I guess.
#write(ofile,int(rand(Seed)*1000000)), where Seed is always changed to use
previously generated random number.
Although I'm unsure how this is any different from simply doing so in the
first place without having to store it externaly.  Not that I'm smart enough
to know otherwise.
Ken <tyl### [at] pacbellnet> wrote in message
news:381AB6D3.676EC919@pacbell.net...
numbers
> >   #read(ifile,R)
> >   #fclose ifile
> > #else
> > #end
> > #fclose ofile
Date: 30 Oct 1999 09:24:53
Message: <381af1a5@news.povray.org>
The part where you write a file to be read the next time. That file will
have a different seed number in it every time and your random result will be
different. I expect it would work just as well if it were...
> > #write(ofile,R+1)
> > #fclose ofile
numbers
> >   #read(ifile,R)
> >   #fclose ifile
> > #else
> > #end
> > #fclose ofile
Date: 31 Oct 1999 03:05:11
Message: <381bf837@news.povray.org>
omniVERSE <inv### [at] aolcom> wrote:
: Although I'm unsure how this is any different from simply doing so in the
: first place without having to store it externaly.
  Show me an example code, thanks.
Date: 31 Oct 1999 03:07:29
Message: <381BF87F.217F1EFD@pacbell.net>
Simple :)
#declare R = seed(1234); <- change this number anytime you want a different value
Date: 31 Oct 1999 03:10:47
Message: <381bf987@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: #declare R = seed(1234); <- change this number anytime you want a different value
  I think that the idea was to get different values without changing the
code... :)
  Btw, who is the F1 champion?-)
Date: 31 Oct 1999 07:02:58
Message: <By8cOEAhoj3f5vCuCb4uriADt1b1@4ax.com>
On 31 Oct 1999 03:10:47 -0500, Nieminen Juha <war### [at] punarastascstutfi> wrote:
The same guy who collapsed in tears a couple of races ago when he spun off in the lead
He deserved to win, however, so well done the Finns (and the Brits/Germans for the
hardware).
David
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Date: 31 Oct 1999 07:42:42
Message: <381c3942@news.povray.org>
I was neglecting the fact about multiple renders, wouldn't be the same then.
Sorry about my confusion. Okay guys you can put the straightjacket back on
me now, through typing.
Think someone brought this up before... if by trying to supply a very small
or large number, then getting integer of some math done on it might return a
different number each time due to inaccuracies. That way it could be used as
the seed ( ) and no need to store one outside of POV.
I've tried it just now though and it doesn't seem possible.
Date: 31 Oct 1999 09:58:04
Message: <381C5945.DAF30177@enter.net>
Novel approach.
> #fclose ofile
Still think you should make stowing the next run's seed the first
thing you do once the stream is instantiated as opposed to putting
it at the end of the file. That way the whole process could be
coded as a #macro, which could be used to instantiate multiple
true random number streams on demand, making it more flexible
in the long run.
