POV-Ray : Newsgroups : povray.general : Photon Map Server Time
22 Jul 2026 06:18:32 EDT (-0400)
  Photon Map (Message 1 to 6 of 6)
Subject: Photon Map
Date: 12 Oct 1999 04:22:47
Message: <3802FE31.94A47F15@umh.ac.be>
Hello everyone,
I just need a simple information (perhaps the answer has been already
give but I didn't see it!). The patch of Nathan Koop (Photon Map) (which
is really fantastic!!, I am Physicist and I appreciate the result) is
made for PovRay 3.1a. Can I use this exe (uvpov.exe) with PovRay 3.1g.
Thanks to give me an answer.
 Fabian.
PS: If Ken read this message, congratulation for your very good french!
J'apprecie beaucoup de voir un anglophone maitriser la langue de Moliere
comme vous la maitrisez! :)
Subject: Re: Photon Map
Date: 12 Oct 1999 05:22:55
Message: <3802fdef@news.povray.org>
You need to trade out the 3.1g file named cmedit.dll in the
\bin\ subfolder of POV-Ray with the older files of version 3.1a.  I use a
DOS batch file to automate the change, but first copy or rename the newer
file to cmedit.dlo and the 3.1a file to cmedit.dlp
so they can be copied around okay.
Photon.bat is as follows:
@echo off
cd \
cd c:\progra~1\pov-ra~1.1\bin
copy /y cmedit.dll cmedit.dlx
copy /y cmedit.dlp cmedit.dll
cd Photon
uvpov.exe
Then to get Official POV back, 31g.bat:
@echo off
cd \
copy /y cmedit.dlo cmedit.dll
pvengine.exe
The *.dlx files are just a safety precaution to retain the last used DLLs.
So,  Photon.bat  gives you the UVPov (photon patch) in a subfolder of \bin\
by the way, and  31g.bat  gets you back again.  I made shortcuts to these
batch files in Windows and use them to switch between the two, also I use a
third batch for the Super Patch.
Super.bat:
@echo off
cd \
copy /y cmedit.dls cmedit.dll
cd Super
spovray.exe
You may need to minimize and re-maximize the POV-Ray window to get it to
display properly, I don't know why it has troubles.
Fabian Brau <fab### [at] umhacbe> wrote in message
news:3802FE31.94A47F15@umh.ac.be...
> Hello everyone,
>  Fabian.
Date: 12 Oct 1999 11:04:05
Message: <38034de5@news.povray.org>
Actually, the newest UVPov can use the 3.1g dlls with no apparent problems
(I upgraded to 3.1g a few weeks ago and have had no problems).  No more need
to swap dlls.  :-)
-Nathan
Bob Hughes <inv### [at] aolcom> wrote...
> @echo off
> cd \
> cd Photon
> uvpov.exe
> @echo off
> cd \
> pvengine.exe
\bin\
a
> Super.bat:
> @echo off
> cd \
> cd Super
> spovray.exe
> Bob
> > Hello everyone,
> >  Fabian.
Date: 12 Oct 1999 22:58:05
Message: <+PQDOIkpB8rbdd3l42eTWwwBoX9F@4ax.com>
On Tue, 12 Oct 1999 11:03:15 -0400, "Nathan Kopp" <Nat### [at] Koppcom> wrote:
>to swap dlls.  :-)
  I can confirm this. I've had no problems using UVPov with v3.1g and Ron
Parker's Superpatch also works seamlessly.
Alan
Date: 13 Oct 1999 05:13:53
Message: <38045BAE.E86E9D1A@umh.ac.be>
Thank you all!
I confirm also that there are no problem!
   Fabian.
> >to swap dlls.  :-)
> Alan
Date: 14 Oct 1999 11:10:24
Message: <3805f260@news.povray.org>
I'm always the last to know.
Thanks in advance then Nathan, Ron, whoever else...
