POV-Ray : Newsgroups : povray.general : An interesting pigment Server Time
29 Nov 2025 23:56:08 EST (-0500)
  An interesting pigment (Message 1 to 7 of 7)
Subject: An interesting pigment
Date: 7 Oct 1999 11:41:51
Message: <37fcbf3f@news.povray.org>
Here's an interesting pigment.  See if you can determine what it'll do before
you render it.  Hopefully someone out there can find a use for this thing.
It's a little long for a signature file a'la Warp, but I think it's worth
posting and I'm sure Ken will appreciate the indenting style:
#declare MysteryPigment=pigment{#local C=array[6]{pigment{color Gray30}pigment{
color Gray30}pigment{color Gray70}pigment{color Gray70}pigment{color White}
pigment{color White}}#local T=sqrt(3);#local B=pigment{radial pigment_map{
#local i=0; #while(i<6)[i/6 C[i]][(i+1)/6 C[i]]#local i=i+1;#end}}radial
pigment_map{#local i=0;#while(i<6)#local a=(i+.5)*60*y;#local s=1.5*T;[i/6
gradient x pigment_map{[1/3 B scale 1/s rotate -a][1/3 B translate vrotate(T*x,
a)rotate -a scale 1/s]}scale s rotate a][(i+1)/6 gradient x pigment_map{[1/3 B
scale 1/s rotate -a][1/3 B translate vrotate(T*x,a)rotate -a scale 1/s]}scale s
rotate a]#local i=i+1;#end}translate x warp{repeat 3*x}warp{repeat T*z}scale .5}
plane { y,0 pigment {MysteryPigment}}
camera { location 12*y sky z look_at 0 }
light_source { 6*y rgb 1}
Subject: Re: An interesting pigment
Date: 7 Oct 1999 12:46:58
Message: <37FCCFF7.C6BEB391@merlin.net.au>
Nice, I like it a lot.
I failed the "guess what it does" test, my excuse is that it's 2:20 AM.
PS. it's a good idea to use upper case for the first character of
variables so they don't clash with future built ins.  This scene crashed
on 'undeclared identifier expected but s found instead'.
Cheers, PoD.
Date: 7 Oct 1999 12:51:57
Message: <slrn7vpjtd.v8.parkerr@ron.gwmicro.com>
Actually, I usually do that.  My excuse is that I got overzealous in
trying to obscure the variable names.  I'm guessing you used the superpatch
to try to render it, eh?
Date: 7 Oct 1999 12:59:05
Message: <37FCD14E.97D157D6@pacbell.net>
Well it is a bit too obfoosticated even for my tastes but I do love the
pattern it creates. I have already bastardized it in half a dozen ways
and love some of the variations that can be obtained with it. I too failed
the test :(
Ken Tyler
1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 7 Oct 1999 13:01:11
Message: <37FCD1CC.8235D11C@pacbell.net>
P.S. A little color rearrangement makes for an interesting height field
     source image.
Ken Tyler
Date: 7 Oct 1999 13:19:06
Message: <37FCD77D.D89F4C3A@merlin.net.au>
Natch.
I figured that you wouldn't want to make the variables stand out in
obfuscated code, but it can't hurt to keep these points in mind (I'll
try to do so myself from now on :> ).
Cheers, PoD.
Date: 8 Oct 1999 04:46:26
Message: <37fdaf62@news.povray.org>
plane { y,0 pigment {MysteryPigment warp{black_hole 0,10 strength -.6}}}
makes it look a bit like a painting I saw once. Kewl.
