POV-Ray : Newsgroups : povray.general : Strange behaviour? Server Time
27 Apr 2026 02:54:09 EDT (-0400)
  Strange behaviour? (Message 1 to 9 of 9)
Subject: Strange behaviour?
Date: 5 Oct 1999 07:14:25
Message: <37f9d4e7.14580615@194.174.214.110>
Hi All,
while trying to track down a bug I found that negative scaling can
make objects disappear and was wondering (not being too well-versed in
POV) whether this is legal or not:
default { pigment { color rgb <1,1,0> }}
union {
  sphere {
    <-1,0,0>,1
  sphere { // Sphere101
    <1,0,0>,1
  cylinder { // Cylndr034
    <-1,0,0>, <1,0,0>, 0.7
  scale 1 // <- Change to -1 and see the spheres disappear
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <20, 40, 50>
camera { location <0,0,6> look_at 0 }
The docs do not say anything about negative scaling. It is
inconsistent in that the cylinder does not disappear, though.
Thoughts?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Subject: Re: Strange behaviour?
Date: 5 Oct 1999 08:28:10
Message: <37F9EF9B.DD0252DD@inapg.inra.fr>
Pretty strange. Negative scaling is perhaps the most useful undocumented
feature of pov.
Could be an epsilon problem + float-to-vector promotion problem ????
scale -1*<1,1.0001,1> works all right
Gilles
Lutz Kretzschmar wrote:
> Hi All,
> union {
>   sphere {
>     <-1,0,0>,1
>     <1,0,0>,1
> light_source
> Thoughts?
> - Lutz
Date: 5 Oct 1999 09:06:05
Message: <37F9F793.C93F696C@peak.edu.ee>
The code itself is OK. The problem seems to be with automatic bounding. Add
manual bounding to the union and the spheres reappear.
Also, if you replace the central cylinder with a sphere, this sphere also
disappears upon scaling. So I don't think the problem is with bounding boxes not
getting transformed (you can also check this by placing the camera along the X
axis - the spheres still won't appear).
Anyway I'm pretty confident it's a bug.
Margus
> Hi All,
> union {
>   sphere {
>     <-1,0,0>,1
>     <1,0,0>,1
> light_source
> Thoughts?
> - Lutz
Date: 5 Oct 1999 16:37:41
Message: <37FA617B.7DF72EC3@skynet.be>
Turning the vista display on (+UD) shows that the bounding is present,
tough it doesn't work as expected...
Fabien.
Date: 5 Oct 1999 17:40:49
Message: <37fa7061@news.povray.org>
The 'sphere' is definately a volitle primitive from what I have seen.  The
bug notion sounds very plausible, at least in the sense that maybe it could
be hardened against such defects maybe.  Possibly not a true bug in the
sense of what is normally expected in everyday use.
Margus Ramst <mar### [at] peakeduee> wrote in message
news:37F9F793.C93F696C@peak.edu.ee...
Add
boxes not
the X
> Margus
> > Hi All,
> > union {
> >   sphere {
> >     <-1,0,0>,1
> >     <1,0,0>,1
> > light_source
> > Thoughts?
> > - Lutz
Date: 6 Oct 1999 01:11:57
Message: <37fada1d@news.povray.org>
Lutz Kretzschmar wrote in message <37f9d4e7.14580615@194.174.214.110>...
>Hi All,
>union
>  sphere {
>    <-1,0,0>,1
>    <1,0,0>,1
>light_source
The problem only occurs when scaling by <-1,-1,-1>.  Scaling by <-1,1,1>,
<1,-1,1>, <1,1,-1>, or anything else doesn't cause problems.
Mark
Date: 6 Oct 1999 20:46:59
Message: <37fbed83@news.povray.org>
(Crossposted to bugreports)
Ah, now it begins to make sense.  See, when you scale a sphere it
multiplies the radius and the center by the scale factor unless it
either already has a nonuniform transform in its list or the scale
factor itself is nonuniform; in those two cases it uses the usual,
more sophisticated methods.
Obviously, making the radius negative is a bad thing.  Here's the
fix, in the function Scale_Sphere in spheres.c:
   if (Sphere->Trans == NULL)
     VScaleEq(Sphere->Center, Vector[X]);
-    Sphere->Radius *= Vector[X];
+    Sphere->Radius *= fabs(Vector[X]);
     Compute_Sphere_BBox(Sphere);
Date: 7 Oct 1999 06:30:02
Message: <37FC75F4.8F7BB1DD@peak.edu.ee>
So why does manual bounding fix the problem?
What happens to the bounding boxes?
Margus
Date: 7 Oct 1999 09:08:05
Message: <37fc9b35@news.povray.org>
I think the negative radius is just fine in the sphere intersection
code, probably because it uses radius squared for its computations
so as to avoid taking square roots.  The problem must happen because
the bounding box ends up being "backwards" - i.e. having a minimum
corner of <1,1,1> and a size of <-2,-2,-2>.  The bounding code must
not be able to handle that.  Setting a manual bounding volume makes
POV-Ray ignore the automatically calculated bounds.
