POV-Ray : Newsgroups : povray.general : cartoon Server Time
27 May 2026 22:20:18 EDT (-0400)
  cartoon (Message 1 to 6 of 6)
Subject: cartoon
Date: 1 Oct 1999 16:02:35
Message: <37f5135b@news.povray.org>
Is it possible to create pictures that look like a drawn cartoon with
POV-Ray.
If yes please give me an example or an URL or a picture.
THANX,
  CU,
    vmx.
Subject: Re: cartoon
Date: 1 Oct 1999 16:24:10
Message: <37f5186a@news.povray.org>
Using a quality setting of 0 or 1 or other low number has been talked of
before for doing "cartoon"-like renders.  Believe it was TonyB who posted an
image at p.b.i. of a similar thing too, although I'm unsure if it had a low
quality setting or not.
Anyhow, it has been thought of before but I doubt there's a whole lot on it
out there.  Perhaps a few people will be able to say something on it.
vmx <vmx### [at] gmxde> wrote in message news:37f5135b@news.povray.org...
> POV-Ray.
> THANX,
>   CU,
>     vmx.
Date: 2 Oct 1999 01:35:14
Message: <37f59992@news.povray.org>
>POV-Ray.
It is possible to create pictures that look like anything in POV-Ray, you
just have to figure out how to do it. For cartoons, I can't really recommend
an optimum system, as I have not found it, and I doubt many have persued it.
Please look for threads with "cartoon" in the title in p.b.i, OK?
Date: 2 Oct 1999 11:12:31
Message: <37F620CD.9DBC0B8A@skynet.be>
> POV-Ray.
There is a possible trick with the "brillance" finish statement.
Someone used it in the "childhood" IRTC, it's an image with bears
around their house (it's a small round, browse a little).
Fabien.
Date: 2 Oct 1999 14:08:35
Message: <37f64a23@news.povray.org>
I did some good stuff by using max_trace_level of 1 and unioning each shape
with a slightly larger one. Then I used a high ambient on some simple
textures, and a large area light. This gave me black lines around the
shapes, flat surfaces with wide highlights, and indistinct shadows. Maybe I
will dig some out and post it in p.b.i, but right when I was working on it
someone posted a reverse watercolor image using a similar method that made
my stuff look like children's work and so I sort of gave up on it...8-(
> POV-Ray.
> THANX,
>   CU,
>     vmx.
Date: 2 Oct 1999 16:45:53
Message: <eW72N9lFHiaWhq5EIxOuT3pooat+@4ax.com>
On Sat, 02 Oct 1999 17:12:13 +0200, Fabien <fab### [at] skynetbe>
>Fabien.
As far as I remember the trick was to boost up brilliance a lot, like
200 or even 1000. I still need to confirm it with an experiment,
though.
Peter Popov
ICQ: 15002700
