POV-Ray : Newsgroups : povray.general : bug in "frequency" keyword? Server Time
22 Jul 2026 03:14:36 EDT (-0400)
  bug in "frequency" keyword? (Message 1 to 8 of 8)
Subject: bug in "frequency" keyword?
Date: 16 Sep 1999 23:13:30
Message: <37e1b1da@news.povray.org>
The texture
          gradient x
          color_map {
             [0  Gray35]
             [1  Gray40]
    //    scale 0.30
          frequency 1/0.30
       }  // end of base texture
is supposed to produce a repeating gradient every 30 centiunits.  However,
there are also lines visible at the position of the original un-modified
gradient.  It's as if both the 0->1 gradient and the 0->0.3 gradient are
layered.
If I use a scale instead of frequency, I get the desired effect.
The docs say that the effects should be identical.
What's up?
--John
Subject: Re: bug in "frequency" keyword?
Date: 16 Sep 1999 23:39:14
Message: <37e3b6a6.257855790@news.povray.org>
On Thu, 16 Sep 1999 22:13:29 -0500, "John M. Dlugosz"
>What's up?
You're misreading the docs.
| The frequency keyword adjusts the number of times that a color map
| repeats over one cycle of a pattern. For example gradient covers color
| map values 0 to 1 over the range from x=0 to x=1. By adding frequency
| 2.0 the color map repeats twice over that same range.
The pattern doesn't change.  Just the color map does.  So saying
  color_map {[0 rgb 0][1 rgb 1]} frequency 2.0
is like saying
  color_map {[0 rgb 0][1/2 rgb 1][1/2 rgb 0][1 rgb 1]}
but saying
  color_map {[0 rgb 0][1 rgb 1]} frequency 1.5
is like saying
  color_map {[0 rgb 0][2/3 rgb 1][2/3 rgb 0][4/3 rgb 1]}
except that that isn't legal.  So POV truncates the color
map at 1.
You're probably referring to this sentence:
| The same effect can be achieved using scale 0.5*x so the frequency keyword
| isn't that useful for patterns like gradient.
The problem is, that sentence isn't definitive.  It just points out
that the results of THAT SPECIFIC OPERATION are identical to a scale.
Noninteger frequencies are not identical to a scale.
Date: 17 Sep 1999 03:22:19
Message: <37e1ec2b@news.povray.org>
Ron Parker <par### [at] fwicom> wrote:
: | The same effect can be achieved using scale 0.5*x so the frequency keyword
: | isn't that useful for patterns like gradient.
  Is this true even if you use 'turbulence'?
Date: 17 Sep 1999 04:01:38
Message: <37E1F4F2.B7749D00@pacbell.net>
I don't see where turbulence would have any effect on the order of the
color map in a pattern. Turbulence will 'bend' the pattern but will not
change it.
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 17 Sep 1999 04:40:15
Message: <37e1fe6f@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
:> : | The same effect can be achieved using scale 0.5*x so the frequency keyword
:> : | isn't that useful for patterns like gradient.
:>   Is this true even if you use 'turbulence'?
: I don't see where turbulence would have any effect on the order of the
: color map in a pattern. Turbulence will 'bend' the pattern but will not
: change it.
  Scaling a "turbulenced" pattern by 0.5*x is certainly not the same as
just setting its frequency to 2. When you scale the pattern, the shape of
the "bending" changes but when you only change the frequency that doesn't
change the shape of the pattern.
Date: 17 Sep 1999 06:29:20
Message: <37E217EB.8B0C84F@peak.edu.ee>
Without testing, I'd say
{gradient x scale .5*x warp{turbulence .5}} =
{gradient x frequency 2 turbulence .5}
Turblence is entirely separate from the pattern; it's a variation of 3d
Perlin noise whose value at point P affects the pattern value at that
point. The difference arises from wether turbulence is or is not
transformed with the pattern. Frequency affects _only_ the pattern.
Margus
Date: 17 Sep 1999 09:39:25
Message: <37e2448d@news.povray.org>
No, because of the order of evaluation.  But my point was that it's not
even true in all simple cases, just in the specific case mentioned in
the docs and in other cases of integer frequency.
Date: 19 Sep 1999 16:35:02
Message: <37e548f6@news.povray.org>
Ron Parker <par### [at] fwicom> wrote in message
news:37e3b6a6.257855790@news.povray.org...
Gotcha.
So the advice on using "frequency" with a texture map, seen a week or two
ago, isn't right either.
--John
