POV-Ray : Newsgroups : povray.general : Unicode Server Time
23 Jun 2026 07:57:44 EDT (-0400)
  Unicode (Message 1 to 6 of 6)
Subject: Unicode
Date: 12 Sep 1999 15:03:30
Message: <37dbf902@news.povray.org>
I've heard mention of a "Unicode Patch" for POV.  Where can I see more
information on it?
Specifically, is it just to allow Unicode in the true-type font text
objects, or will it allow me to use greek letters as variable names and
macro parameters?
--John
Subject: Re: Unicode
Date: 12 Sep 1999 15:11:31
Message: <37DBFA7D.E64C33B@pacbell.net>
> information on it?
> macro parameters?
> --John
I do not know anything specific about the patch but it can be found here:
http://www.geocities.com/SiliconValley/Network/4453/unipatch/
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 12 Sep 1999 23:23:00
Message: <slrn7toa6g.kq.parkerr@linux.parkerr.fwi.com>
On Sun, 12 Sep 1999 14:03:25 -0500, John M. Dlugosz <joh### [at] dlugoszcom> wrote:
>information on it?
>macro parameters?
It's only a text object patch, it has no effect on what the parser considers
to be a character or on what the editor will allow you to input.
Date: 13 Sep 1999 04:05:29
Message: <37DCAFFA.CF25537D@geocities.com>
> >information on it?
> >macro parameters?
There was some talk of wanting to at least allow different languages in the
comments. The main problem is that the text display is fairly isolated, whereas
the parsing is more of all over. Given that the Unicode patch was my first
effort to mess with POV-Ray code, I'm not up to speed on wholesale changes.
Of course since at least one member of the POV-Ray team had been asking me about
this, I might try to look into it if there are actuall people who want to use
it.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 13 Sep 1999 09:52:37
Message: <slrn7tq0d6.v8.parkerr@ron.gwmicro.com>
The part you'd want to change, though, is mostly a smallish case statement
in tokenize.c.  At the moment, it treats a-z, A-Z, and _ as the beginning of
a symbol.  You'd want to make it treat anything with the high bit set as a
symbol as well.  You'd also need to modify the Read_Symbol code to recognize
and parse correctly characters with the high bit set.  This would allow
high-bit characters to be used inside of declared symbols, which includes
macro names and arguments.  There'd probably also be a few small modifications
needed to some error-reporting code, unless you're comfortable with sending
UTF-8 to the error stream in the event of an undefined symbol or the like.
Believe it or not, the tokenizer can already deal with high-bit UTF-8 characters
inside of comments and literal strings.  The built-in editor in the Windows
version can't, of course, but I'd expect someone using UTF-8 to use something
more suited to Unicode, such as Unipad.
Parsing UCS-2 or UCS-4 would be a lot more difficult, of course.
Date: 13 Sep 1999 12:21:03
Message: <37DD247A.11528BC@geocities.com>
That's a good start, thanks. But here are few more problems than that :-(
I'd need to go through things to make sure that the "right" thing is done for such
as chr(), asc(), etc. There are several different logical approaches to the
problem, but backwards compatibility is one of the biggies. Also need to handle
invalid UTF-8, etc.
Guess I'd better get on it.
