![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am making a flat top pyramid, 4 sided.
What I need to know -
1. How can I precisely position the thing?
2. How can I precisely define the height - or, how does the starting
point number work?
#declare Base6 = prism
linear_spline
conic_sweep
0.83, // What's the precise height? Where is this surface located?
Should be 38 units high.
1,
5,
<32, 32 >,
<-32, 32 >,
<-32, -32 >,
<32, -32 >,
<32, 32 >
sturm
rotate <180, 0, 0>
translate <0, 0.119, 0>// it's actually located at -142y. How'd it
get there with a +0.119 tanslation?
scale <1, 204, 1>// starting pyramid is 204 units high by 32 units
square base.
THANKS for any help ya'll can offer!
steve
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You can tray this
#declare My_Prism = prism{
linear_spline conic_sweep 0, 1, 5,
<-1,-1>, <-1,1>, <1,1>, <1,-1>, <-1,-1>
translate -y rotate 180*x
object{My_Prism
scale <32,38,32>
pigment{pigment}
Alberto.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sun, 01 Aug 1999 14:56:59 -0500, Steve <ste### [at] puzzlecraft com> wrote:
>point number work?
> linear_spline
> conic_sweep
> 1,
> 5,
> <32, 32 >,
> <-32, 32 >,
> <-32, -32 >,
> <32, -32 >,
> <32, 32 >
> sturm
> rotate <180, 0, 0>
>square base.
>steve
Steve,
You need to scale, rotate, translate in that order.
This little macro does the trick for any dimensions and leaves the frustrated pyramid
sitting on <0,0,0>.
David
// --------------------pyramid macro--------------
#macro Pyramid_4_Side(Apex,Height,Side)
prism
conic_sweep
1,
1-Height/Apex,
5,
<Side, Side >,
<-Side, Side >,
<-Side, -Side >,
<Side, -Side >,
<Side, Side >
scale <1,Apex,1>
rotate <180, 0, 0>
translate <0, Apex, 0>
object { Pyramid_4_Side(204,38,32)
pigment { Red }
//-----------------end of program
dav### [at] cwcom net
http://www.hamiltonite.mcmail.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks David - I'll give it a try.
As a workaround I can always write a bicubic_patch, but that's a lot of work.
steve
David Wilkinson wrote:
> Steve,
pyramid
> sitting on <0,0,0>.
> David
> prism
> conic_sweep
> 1,
> 1-Height/Apex,
> 5,
> <Side, Side >,
> <-Side, Side >,
> <-Side, -Side >,
> <Side, -Side >,
> <Side, Side >
> scale <1,Apex,1>
> rotate <180, 0, 0>
> #end
> pigment { Red }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
