POV-Ray : Newsgroups : povray.general : Need help creating an effect Server Time
28 May 2026 05:33:21 EDT (-0400)
  Need help creating an effect (Message 1 to 2 of 2)
Subject: Need help creating an effect
Date: 23 Jul 1999 11:59:05
Message: <37989149@news.povray.org>
I have an Image that I rendered for the last IRTC and have now adapted for
the local Bike Club Tee Shirt. I want to place a Script logo over the image
so that it looks like a floating banner. I have a height field for the
script that looks just right (like fingernail polish) and I map the image on
a plane then put the script HF in front of that (see SCFW in p.b.i)(soon)
but that makes the script flat. I thought of putting the shuttle image on
the inside of a cylinder then using an unusual camera to make that seem flat
and the script bulge, but I really want undulation, not bulge.
    I hope I have described this well, any suggestions?
Subject: Re: Need help creating an effect
Date: 23 Jul 1999 12:15:22
Message: <37989492.2E6762A6@pacbell.net>
  You take a look at the sine wave surfer a texture making utility at:
http://webclub.solutions.fi/~xtmb/sws/index.htm
  There is a waving flag animation in one of the groups here I might be able
  to locate for you if you want me to track it down.
  Here are a few examples of sine wave shapes you might be able to adapt to
  your needs.
  // Sine wave shape example
  #declare Amplitude=1;
  #declare Cycles=3;
  #declare StartAngle=pi*3/2;
  #declare WaveStartX=-5;
  #declare WaveWidth=10;
  #declare ItemAmnt=100;
  #declare Item=sphere { 0,.1 pigment { rgb <1,0,0> } finish { specular .5 } }
  #declare Index=0;
  #while(Index<ItemAmnt)
  #declare Angle=StartAngle+2*pi*Cycles*Index/ItemAmnt;
  #declare PosX=WaveStartX+WaveWidth*Index/ItemAmnt;
  #declare PosY=Amplitude*sin(Angle);
  object { Item translate <PosX,PosY,0> }
  #declare Index=Index+1;
  #declare i=0;
  #while (i<90)
  sphere {0,1 pigment {rgb <1,0,0>}finish {ambient 1.0}
  translate <i,10*sin(i*pi/30),0>}
  #declare i = i + 1;
  // Sine wave shape with face rotation added
  #declare i=0;
  #while (i<90)
  #declare angle1 = i*pi/30;
  box {<-0.5,-0.5,-0.5>,<0.5,0.5,0.5>
  finish{ambient 1.0}
  rotate <0,0,-45*sin(angle1)>
  translate <i,10*sin(angle1+pi/2),0>}
  #declare i = i + 1;
  #end;
Good  luck,
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
