POV-Ray : Newsgroups : povray.general : The Ghost of POV effect Server Time
22 Jul 2026 12:07:31 EDT (-0400)
  The Ghost of POV effect (Message 1 to 2 of 2)
Subject: The Ghost of POV effect
Date: 15 Jul 1999 20:29:21
Message: <378e7ce1@news.povray.org>
Try to render the little animation below and you will see the Ghost of POV
effect caused by union and wood normals (name made up by Uwe Zimmermann I
think). 10-20 frames is enough to get the idea.
I still wonder what actually causes the weird effect.
Can any of the programmers explain it?
   location y/50
   angle 150
   look_at 0
light_source {100*y, color 1}
#declare X = clock;
#declare Y = pow(10,X*2-1);
plane {
   y, 0
   pigment {color 0}
   normal {onion 1.5*Y sine_wave scale 1*Y}
   finish {ambient 0 diffuse 0 phong 1 phong_size 300}
// Also try to rotate the effect... It's impossible!
Greetings,
Rune S. Johansen
Visit The RSJ Website at http://welcome.to/rsj
for 3D images including still lives, dragons,
mathematical shapes, and more. Stereograms,
tutorials, The POV Desktop Theme, all the jokes
"you know you have been raytracing too long when",
miscellaneous other things, and a lot of fun!
Subject: Re: The Ghost of POV effect
Date: 16 Jul 1999 00:55:07
Message: <378EBBD8.507AFE72@Kopp.com>
You mean those three mysterious light/dark spots?  That's caused by the
algorithm used to find the surface normal.  The algorithm (in the function
Perturb_Normal in the file normal.c for you programmers) uses a pyramid
of points to sample the normal map (here a simple onion pattern) to
determine the surface normal.  This locus of points is chosen at a
specific 'radius' around the sample point.  The 'radius' of this
pyramid of points is chosen by DELTA which is defined just prior to
Perturb_Normal.  By changing the value of DELTA I can make these dark
points move in and out.  Getting rid of them is something I do not know
how to do, though.  And making DELTA smaller or bigger causes other
problems.
-Nathan
