POV-Ray : Newsgroups : povray.general : Multiple media vs. multiple containers Server Time
23 Jun 2026 16:58:48 EDT (-0400)
  Multiple media vs. multiple containers (Message 1 to 4 of 4)
Subject: Multiple media vs. multiple containers
Date: 3 Jul 1999 16:47:37
Message: <378070b4.106214832@204.213.191.228>
Hi there.
Here're the results from the tests I promised. Sorry it took me so
long, but it's media, you know...
Please see p.b.s-f for the code and p.b.i for example images.
Type 1 - multiple densities
type1_1.tga, Quality 2  -  7 minutes
type1_2.tga, Quality 3  - 21 minutes
type1_3.tga, Quality 4  - 29 minutes
Type 2 - multiple containers
type2_0.tga, Quality 1  -  4 minutes
type2_1.tga, Quality 2  -  6 minutes
type2_2.tga, Quality 3  - 17 minutes
type2_3.tga, Quality 4  - n.a. sorry, dad played freecell :(
type2_2.tga, Quality 5  - 37 minutes
Multiple containers are faster and with better quality. The examples
posted in p.b.i. show a particle system of 50 particles. Using
multiple containers, the result was much less grainy and was rendered
in 6 minutes vs.29 for multiple media. The results differ slightly but
that's due to the small accuracy of type 1.
I also did a 100 frames 100x100 anim. It started with a single
particle and added a particle every frame (if anyone's interested I'll
post it). Here're the stats:
Type 1 (multiple media) statistics:
Total time: 3:16:34, render 3:16:11, parse 0:0:23
Intersections:
Shape		Tests		Succeeded	Percentage
Sphere		419435		1708050	70.60
Bounding Box	3831950		3830350	99.95
Vista		1030320		1030320	100.00
Media:
Intervals	4963140
Samples		34746921	7.00 per interval
Transmitted rays		1418040
I-Stack overflows		7125
Memory:
Smallest	26
Largest		8216
Peak		134132
command line:
+w100 +h100 +mb0 +uv +kfi0 +kff99 -d +a0.4 +r2
Type 2 (multiple containers) statistics:
Total time: 2:59:18, render 2:58:39, parse 0:0:16
Intersections:
Sphere		54614525	37059270	67.86
Bounding Box	266093261	113576463	42.68
Vista		19936209	12944728	64.93
Media:
Intervals	45169600
Samples		313641496	6.94 per interval
Transmitted rays		7248496
I-Stack overflows		989
Memory:
Smallest	26
Largest		8216
Peak		198691
System: K6/233 96 RAM running POV-Ray for windows 3.1e on 98
command line: +w100 +h100 +mb0 +uv +kfi0 +kff99 -d +a0.4 +r2
(These look fine using Lucida Console)
The main disadvantage of type 1 is that all densities are calculated
for every interval and every sample. This leads to graininess and
inaccuracy because small radius densities may not be hit at all.
The main disadvantage of type 2 and it is that max_trace_level and
max_intersections should be really high. This could be really painful
in scenes with reflective / refractive objects. I've put in a type 3
which uses merge to avoid the problem, but preliminary tests show that
it's slower than type 1 (though more accurate).
Well, that's it for now. Any comments?
Peter Popov
ICQ: 15002700
Subject: Re: Multiple media vs. multiple containers
Date: 3 Jul 1999 18:08:44
Message: <377E89D4.55B31E3D@aol.com>
Okay, so as I understand it, the grainier image is multiple media and
the smoother of the two is multiple containers (the images posted at
p.b.i.).
Peter Popov wrote:
> Hi there.
> Intersections:
> Media:
> Intervals       4963140
> Memory:
> Smallest        26
> Largest         8216
> Peak            134132
> command line:
> Intersections:
> Media:
> Intervals       45169600
> Memory:
> Smallest        26
> Largest         8216
> Peak            198691
> Peter Popov
> ICQ: 15002700
 mailto://inversez@aol.com?Subject=PoV-News
Date: 4 Jul 1999 14:48:43
Message: <377fac8b@news.povray.org>
Peter Popov <pet### [at] usanet> wrote:
: The main disadvantage of type 2 and it is that max_trace_level and
: max_intersections should be really high. This could be really painful
: in scenes with reflective / refractive objects.
  It would be fine if you could specify a max_trace_level for an object.
This way you could have a very high global max_trace_level and a glass
object with a smaller one. Like this:
global_settings { max_trace_level 20 }
object { WaterGlass max_trace_level 5 }
  This could mean that when a ray hits the WaterGlass object, it will be
reflected/refracted up to 5 times instead of 20 if the reflected/refracted
ray hits the same WaterGlass object again.
Date: 4 Jul 1999 19:11:32
Message: <377fe939.34127443@204.213.191.228>
I think this will be really helpful. Until someone actually implements
this, the two ways to avoid max_trace_level problems are blobs and
merge, but of course they are slower and with poorer quality than a
simple union of spheres.
Peter Popov
ICQ: 15002700
