POV-Ray : Newsgroups : povray.general : Req: Candy Cane Server Time
28 May 2026 08:06:54 EDT (-0400)
  Req: Candy Cane (Message 1 to 10 of 21)
Subject: Req: Candy Cane
Date: 25 Jun 1999 15:55:27
Message: <3773DF05.DF3FF07D@pacbell.net>
Hi ?
  Does anyone have a stripped candy cane they could share with me. I
can model the thing all right but getting the stripe to wrap around the
bend properly is giving me epileptic fits. I prefer a non patch solution
for this if at all possible.
Thank you in advance for any help you may have to offer.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Req: Candy Cane
Date: 25 Jun 1999 17:47:29
Message: <3773f8f1@news.povray.org>
On Fri, 25 Jun 1999 12:56:53 -0700, Ken wrote:
>Hi ?
That sounds difficult.  You might find it easier to write a script
to generate the stripe as a mesh that's just slightly larger than
a white candy-cane object.  Or of course you can see if the Object
Bender does what you need.
Date: 25 Jun 1999 18:19:06
Message: <377400AF.814E9A8B@pacbell.net>
> >Hi ?
 Unfortunatly I am not too adept at writing triangle construction scripts
so that rules out that option. The object bender is still an option I
have not overlooked but would like to avoid this too as I plan to create
possibly hundreds of duplicates and the parse time MAY be unnaceptable.
I have no experience with that particular inc file but have heard that
it is prohibitavly slow if the radius of the bend is excessive. A candy
can has a bend that exceeds 180 degrees which borders on excessive.
Ken Tyler
Date: 26 Jun 1999 02:31:58
Message: <377473D5.D911D700@aol.com>
Sounds like a job for some sort of twisting on a torus slice unioned with the usual
cylinder and candy cane stripe texture (duh). Haven't done it myself. There's
Spiralizer
here:
 http://www.armanisoft.ch/webdesign/default.htm
Just not sure of it's use for this particular purpose (makes 3D models not textures).
I couldn't find one of the many twisting spiral includes among my several links here
but
maybe theres a way to apply such a thing if you can locate one or if someone knows of
the whereabouts and can lead you to something, plus it seems the more plausible
alternative too.
Actually best of all would simply be a 'image_map' with 'map_type 5' applied to the
torus slice (wide red and white diagonal lines). Leave it to me to think of the best
solution last.
 mailto://inversez@aol.com?Subject=PoV-News
Date: 26 Jun 1999 06:44:37
Message: <3774B015.24EE7734@compuserve.com>
I have posted a candy cane model in the text scene files newsgroup.
Date: 26 Jun 1999 06:46:47
Message: <3774B098.9F1A5DC4@compuserve.com>
Grr, I can't get it to post. I seem to be having a problem with long
messages. I will e-mail it to you.
Date: 26 Jun 1999 07:09:38
Message: <3774B54A.98096571@pacbell.net>
 Thank you very much !
Ken Tyler
Subject: Re: Candy Cane
Date: 26 Jun 1999 11:01:44
Message: <3774eb58@news.povray.org>
I would, but I've already licked it...
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
For a totally different experience, visit my Chroma Key Website:
Colorblind - http://listen.to/colorblind
Date: 26 Jun 1999 21:26:10
Message: <37787ded.755887246@news.povray.org>
Kinda on this same topic...
It sure would be nice if there were a spiral pattern that varied angle
only with y.  That is to say, one like spiral1 but with a
cross-section that looks like radial.  Am I alone in thinking this?
Date: 26 Jun 1999 21:27:08
Message: <37797e51.755988064@news.povray.org>
On Sun, 27 Jun 1999 00:56:46 +1000, "Lance Birch"
That's perfect.  He wanted a stripped one anyway.  Now if he wanted a
striped one, then you might have cause to be concerned.
