POV-Ray : Newsgroups : povray.general : Gradient? Server Time
30 Nov 2025 08:20:47 EST (-0500)
  Gradient? (Message 1 to 3 of 3)
Subject: Gradient?
Date: 9 Jun 1999 16:44:51
Message: <375ed243@news.povray.org>
In the scene below, I try to make a plane with the texture, first quarter black,
second white and the tophalf is a gradient from black to white. Well, that's
what I expected, but the top half shows a gradient form 50% to white. Why?
(Tried the same setup with a texture_map, with the same result)
How to get the result I want?
ingo
Met dank aan de muze met het glazen oog.
#declare CamLoc=-15*z;
  location CamLoc
  look_at z
  angle 90
  orthographic
plane {
   -z,-100
   no_shadow
      gradient y
      scale 24
      pigment_map {
         [0.25, rgb 0]
         [0.25, rgb 1]
         [0.5 , rgb 1]
         [0.5 , gradient y]
      translate <0,-12,0>
   finish {ambient 1}
Subject: Re: Gradient?
Date: 9 Jun 1999 17:46:37
Message: <375ee0bd@news.povray.org>
Try this instead:
      pigment_map {
         [0.25, rgb 0]
         [0.25, rgb 1]
         [0.5 , rgb 1]
         [0.5 , gradient y
           color_map {
             [.5 rgb 0]
             [1 rgb 1]
The problem is that 'gradient y' maps the interval from y=0 to y=1
into the default color map, which is {[0 rgb 0][1 rgb 1]} for the gradient
pattern.  This happens even when the gradient is specified within a pigment
map.  This means that where y=.5, the color will be 50% gray.
There's an easier way to do this, too, if this result is really what you're
looking for and you haven't simplified it for the sake of debugging:
      pigment_map {
         [0.25, rgb 0]
         [0.25, rgb 1]
         [0.5 , rgb 1]
         [0.5 , rgb 0]
         [1.0 , rgb 1]
Date: 10 Jun 1999 04:36:42
Message: <375f791a@news.povray.org>
Ron Parker heeft geschreven in bericht <375ee0bd@news.povray.org>...
Obvious. I should have known this.
Ah, this is indeed what I'm looking for. I came from a situation with several
gradients. Then a strange circular thinking pattern keeps you from seeing the
simple solution :(
Thanks Ron.
ingo
