![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
While making some pieces of wood with different colours, using random, I ran
into a problem.
Run the scene below.
The first number from the random stream ia always 0.118 .
Now comment out "#declare XX = ....." , "#debug concat(....." and in the the
first pigment replace XX by "Rmm(0.1,0.5,Sd)".
Run the scene again.
Why are the colours different?
ingo
Met dank aan de muze met het glazen oog.
#version 3.1; global_settings {assumed_gamma 1.0}
light_source {<500, 500,-500> rgb 1}
camera {location<0, 1.6, -5.0> look_at<0,0,0>}
#declare Sd=seed(7)
#macro Rmm(Min,Max,Stream)
Max+((Min-Max)*rand(Stream))
#end //macro
#declare XX= Rmm(0.1,0.5,Sd)
#debug concat("\n XX= ",str(XX,3,3))
#declare Wood= texture {
pigment {rgb <0.50,0.10,0.08>*XX}
wood
scale 0.05
color_map {
[0,rgbf <0.5,0.4,0.4,0.2>*0.5]
[1,rgbf <0.5,0.4,0.4,0.7>*0.5]
box {-1,1 texture {Wood}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Macros work via text substitution. Rmm is not really a function returning
a number.
Right now, this:
pigment {rgb <0.50,0.10,0.08>*Rmm(Min,Max,Stream)}
becomes:
pigment {rgb <0.50,0.10,0.08>*Max+((Min-Max)*rand(Stream))}
So, you need to put parentheses in the macro. Change it to look like
this:
(Max+((Min-Max)*rand(Stream)))
#end //macro
-Nathan
> into a problem.
> ingo
> #declare Sd=seed(7)
> #end //macro
> texture {
> pigment {
> wood
> scale 0.05
> color_map {
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Nathan Kopp <Nat### [at] Kopp com> wrote in message
news:3740DC55.26A3866B@Kopp.com...
> a number.
POVRay documentation says differently, see: "Returning a value from a
macro" or some such. I'm too groggy to think about his macro but it can be
made to act like a value in the pigment.
> Right now, this:
> becomes:
> this:
> #end file://macro
> -Nathan
ran
> > into a problem.
the
> > ingo
> > #declare Sd=seed(7)
> > #end file://macro
> > texture {
> > pigment {
> > wood
> > scale 0.05
> > color_map {
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ahh, I see, thanks,
ingo
Nathan Kopp heeft geschreven in bericht <3740DC55.26A3866B@Kopp.com>...
>a number.
>Right now, this:
>becomes:
>this:
>#end //macro
>-Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The section "Returning a Value Like a Function" talks about needing the
extra set of parentheses.
-Nathan
> > a number.
> > Right now, this:
> > becomes:
> > this:
> > #end file://macro
> > -Nathan
> ran
> > > into a problem.
> the
> > > ingo
> > > #declare Sd=seed(7)
> > > #end file://macro
> > > texture {
> > > pigment {
> > > wood
> > > scale 0.05
> > > color_map {
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You are right, after a nap I was able to see what you meant. Before the nap
all I could read was the part about text substitution, and I had just set up
some macros that returned a value via a variable.
I apologize for my brain dead assertions.
news:3741E76C.5F723D9B@Kopp.com...
> -Nathan
returning
> > > a number.
a
be
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
