POV-Ray : Newsgroups : povray.general : Decorating an object Server Time
1 Dec 2025 15:10:13 EST (-0500)
  Decorating an object (Message 1 to 2 of 2)
Subject: Decorating an object
Date: 21 Apr 1999 16:44:45
Message: <371E2AA7.E8987DDD@gyltech.com>
Hi
I have a box which will be in a scene and I want to put logos, a
starburst and text on it. The text part is no problem. I would like to
know how to take an image like a starburst with type in it from
Photoshop and place it on the object at a certain point.
Does POV have a way of doing this or should I try importing the object
into a modeller?
Thanks a bunch,
Raymond Gilford
Subject: Re: Decorating an object
Date: 21 Apr 1999 18:39:37
Message: <371E4569.48B8A4F8@aol.com>
//box with image mapped on
 box {0,1
   image_map {tga "starbtxt.tga" map_type 0} //use tga, png, gif, (bmp
maybe?)
 translate <-.5,-.5,-.5> //center these
  scale <3,2,1> //scale to original image width height ratio
This would be okay, except it will texture the box all the way through
from front to back (mirrored image on reverse side) and also show the
image boundry color on the other faces.
To circumvent that you would need to either add a second slightly larger
box with the front clipped away or map to a plane instead and clip that
with the box while also adding the box.
union {
 box {0,1}
 plane {z,0
maybe?)
 clipped_by {box {0,1 translate -.5*z}}
 } //end plane
 } //end union
"Raymond C. Gilford" wrote:
> Hi
> into a modeller?
> Thanks a bunch,
> Raymond Gilford
