POV-Ray : Newsgroups : povray.general : Trce in superpatch Server Time
30 Nov 2025 13:57:45 EST (-0500)
  Trce in superpatch (Message 1 to 8 of 8)
Subject: Trce in superpatch
Date: 6 Apr 1999 14:04:02
Message: <370a3e82.0@news.povray.org>
Hi All
when I run the following code not only do I get 100 spheres but as the code
loops it also draws the slab a hundred times or so.
Can anyone suggest a way of using trace in a way that the object is only
drawn once? Otherwise the memory hit with high samples is horrendous!
Mick
#version 3.1;//Superpatch
camera
  location  <0.0, 10, -20.0>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 0.0,  0.0>
sky_sphere
  pigment
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source{<-30, 30, -30>,color rgb<1,1,1>}
#declare Step2 = box{<-2, 0, -2>< 2,  .4,  2> pigment{Yellow}}
#declare Norm = <0,0,0>;
#declare Xpos = -5;
#declare Zpos = 5;
#while (Xpos<6)
   #while (Zpos>-6)
        #declare SPos = <Xpos,1,Zpos>;
        #declare Inter = trace (Step2,SPos,<0,0,0>-SPos, Norm );
                object{Step2 texture {pigment{color rgb<1,1,0>}}}
                        #if (Norm.x != 0 | Norm.y != 0 | Norm.z != 0)
                                sphere{Inter,.1 texture{pigment{color red
1}}}
    #declare Zpos = Zpos -1;
    #declare Zpos = 5;
  #declare Xpos = Xpos +1;
Subject: Re: Trce in superpatch
Date: 6 Apr 1999 14:20:36
Message: <370a4264.0@news.povray.org>
On Tue, 6 Apr 1999 17:50:18 +0100, Mick Hazelgrove wrote:
>Hi All
Could you just move the "object {step2..." line outside the while loop?
Date: 6 Apr 1999 14:36:02
Message: <370a4602.0@news.povray.org>
Thanks Ron
That does it
Now how can I use trace to test the height of a HF... Hmmmm
Mick
Ron Parker <par### [at] my-dejanewscom> wrote in message
news:370a4264.0@news.povray.org...
> >Hi All
code
Date: 6 Apr 1999 17:10:09
Message: <370A6A36.F738CC88@kolumbus.fi>
> Thanks Ron
> That does it
> Mick
It's quite simple actually
#declare your heigtfield (eg. #declare HF=heightfield{...})
#declare the maximum height of the heightfield (#declare MaxHeight=(the
y-scale of the hf + 1)
then when you want to know the heigth at point (x,z)
just trace(HF,<x,MaxHeight,z>,<0,-1,0>)
I did this straight from my memory so there might be some errors but
hopefully you get the main idea
Date: 6 Apr 1999 20:14:18
Message: <370a954a.0@news.povray.org>
Why not simply trace from below, e.g. trace(HF,<Px,-1,Pz>,y)
Margus
Subject: Re: Trce in superpatch; trace????
Date: 14 Apr 1999 16:56:33
Message: <3714f2f1.0@news.povray.org>
Mick Hazelgrove <mha### [at] mindaswinternetcouk> schrieb in im Newsbeitrag:
370a3e82.0@news.povray.org...
> Hi All
code
> Mick
> camera
>   direction 1.5*z
>   right     4/3*x
> sky_sphere
>   pigment
>     gradient y
> #declare Xpos = -5;
> #declare Zpos = 5;
> #while (Xpos<6)
>    #while (Zpos>-6)
> 1}}}
>                         #end
>     #end
>     #declare Zpos = 5;
> #end
looks like a macro defined somewhere else!
Hm would be nice if you could make me wiser!
Smarf
Date: 14 Apr 1999 18:13:14
Message: <371504ea.0@news.povray.org>
Trace isn't a macro, it's a function that exists only in the Superpatch,
available at http://twysted.net/patchstation .  It is used to find the
intersection of an arbitrary ray with an arbitrary object and is useful
for such things as placing objects on height fields or growing creeping
ivy in POV scripts.
Date: 15 Apr 1999 04:28:31
Message: <3715951f.0@news.povray.org>
Hi
There you go - I couldn't of put it better if I'd written the superpatch:)
Mick
> ivy in POV scripts.
