POV-Ray : Newsgroups : povray.general : matrix question Server Time
28 Mar 2026 17:41:00 EDT (-0400)
  matrix question (Message 1 to 8 of 8)
Subject: matrix question
Date: 30 Mar 1999 17:41:01
Message: <370152fd.0@news.povray.org>
Normally a matrix can transform
an object so the point x can become
P1, y can become P2, z can become
P3 and the origin becomes P4.
How can I do this thing backwards?
I.e. P1 becomes x, P2 becomes y,
P3 becomes z, and P4 becomes the
origin. The way I tried it I only
got a lot of divide by zero warnings.
Thanks,
Rune S. Johansen
http://hjem.get2net.dk/rsj
Subject: Re: matrix question
Date: 31 Mar 1999 02:11:34
Message: <3701caa6.0@news.povray.org>
Rune S. Johansen <run### [at] get2netdk> wrote:
: Normally a matrix can transform
: an object so the point x can become
: P1, y can become P2, z can become
: P3 and the origin becomes P4.
: How can I do this thing backwards?
  I think that in this case you have to transform them with the inverse of
the matrix.
  Somebody can tell you how the inverse of a matrix is calculated.
Date: 31 Mar 1999 08:53:19
Message: <qqmbth93gvk.fsf@goldach.fmi.uni-konstanz.de>
"Rune S. Johansen" <run### [at] get2netdk> writes:
In practice, the matrix keyword in povray divides into a
- a linear function given by the matrix entries Val00 to Val22
- a transformation given by Val30 to Val32
If you want to calculate the inverse function, you have to
- invert the 3x3 matrix Val00 to Val22
- take the negative of the vector Val30 to Val32
How to calculate a inverse matrix should be described in every
linear algebra book. Keep in mind, that not every matrix is
invertible.
I hope this helps
http://www.fmi.uni-konstanz.de/~willhalm
Date: 1 Apr 1999 02:16:02
Message: <37031d32.0@news.povray.org>
Hmm, wait a second, you can't "invert" a matrix can you?  You need an
operation to do that... (e.g. a*aT). I'm studying Set and Group Theory and
Logic at the moment and as far as I can see, I think you are either talking
about the transpose of the matrix or matrix multiplication by the transpose
of the matrix (in which you are correct, you can't *multiply* all matrices
because they need to have order [a,b] [c,a])
Or do you mean scalar multiplication on the matrix with an operator?
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Date: 1 Apr 1999 08:19:34
Message: <37037266.0@news.povray.org>
The inverse of a (square) matrix A is the matrix A' that satisfies
the property A x A' = I, where I is the identity matrix and x stands
for the matrix multiplication operator[1].  A' may or may not exist for
a given matrix A, but if it does it is unique.
[1] I wish more people understood \TeX notation...  $A\times A^{-1}=I$.
Date: 1 Apr 1999 22:03:44
Message: <37043390.0@news.povray.org>
Ah, OK, now I see what you mean!  Of course, I should have thought of that,
it's the same in Set Theory...  [Lance needs more caffeine...and more
sleep...]
Lance.
Date: 2 Apr 1999 21:49:28
Message: <37058337.E3616EBD@erols.com>
This should be "translation."
Pretty much; IIRC, the inverted 3x3 has to be applied to the
negated vector to yield the final result.  I've been scribbling
notes for a suite of macros to fiddle with matrices, mainly
because (a) there is no one-stop-shop for inverting a general
matrix in POV-Ray (without doing the math oneself), (b)
POV-Ray does not provide access to the elements within a
transform, and (c) I wanted to provide a macro with the package
to explicitly perform shears.
> invertible.
Yes, but the matrices that are not invertible are not valid for
use in transformations.  They're easy to spot:  The first nine
elements, when taken as a 3x3 matrix, yields a determinant = 0.
If you give one of these to POV-Ray, you'll get a fatal error.
John
Date: 4 Apr 1999 17:15:06
Message: <3707c84a.0@news.povray.org>
>> invertible.
>Regards,
>John
So, I should be able to get the inverse function in ANY case.
I'd just appreciate an example or two so I will be able to
understand how.
Thanks,
Rune S. Johansen
