POV-Ray : Newsgroups : povray.general : realign math help Server Time
24 Jun 2026 06:29:43 EDT (-0400)
  realign math help (Message 1 to 2 of 2)
Subject: realign math help
Date: 28 Mar 1999 08:48:33
Message: <36fe3331.0@news.povray.org>
Wanted:
realign (sp1,sp2,sp3,sp4,ep1,ep2,ep3,ep4)
I want a macro that transform an object
in the following way:
I give the macro four points.
Then I tell the macro where I want to
move each of the point to.
A matrix can do that if the startpoints
are x, y, z, and the origin but in this
macro it can be any points.
Maybe the macro could also do the
calculations with only the three first
points if I write the string "auto" in
place of startpoint4 and endpoint4.
I can find quite some uses for this macro:
1) together with the "knee" macro from
   "macs.inc". Now the leg can be made
   of more complicated objects.
2) When trying to make uv-texture-mapping
   (also in animations).
3) Much more uses which I can't remember
   right now.
Any help appreciated!
Thanks,
Rune S. Johansen
http://hjem.get2net.dk/rsj
Subject: Re: realign math help
Date: 28 Mar 1999 09:17:36
Message: <36FE38E7.BEE6D932@pacbell.net>
Rune S. Johansen wrote:
> Wanted:
>    right now.
> Thanks,
> Rune S. Johansen
  Did you by any chance check out the macro station at http://twysted.net .
There are several macros there that are based on reorienting objects,
points in space etc. You may get some inspiration there or you might
even find what you need already complete.
Ken Tyler
mailto://tylereng@pacbell.net
