POV-Ray : Newsgroups : povray.general : Surface of a sphere Server Time
30 Nov 2025 17:29:10 EST (-0500)
  Surface of a sphere (Message 1 to 4 of 4)
Subject: Surface of a sphere
Date: 21 Feb 1999 15:34:47
Message: <36d06de7.0@news.povray.org>
Hi all,
I'm not sure how to describe what I want to be able to do, but I'll try.
Lets say that I create, by CSG, a shape that can be described thus:
Start with a sphere. On the surface, describe a square equivalent to 18 degrees of the
entire sphere, then narrow it until at the centre it becomes zero. What I'm trying to
describe is a segment or wedge.
What I want to know is..what is the math that would allow me to reconstruct a sphere
out
of these pieces. I could type each rotation by hand, but I want to be able to apply
random
scaling with regards to the radius of the sphere that each segment originates from. By
that I mean that one segment could have come from a sphere with radius 1, while
another
could have come from a sphere with radius 1.4 etc...so the end result would be a
sphere
made up of segments varying in height, but all being 18 degrees of the entire surface.
I apologise if my explanation is unclear. If you don't understand, then let me know
and
I'll try again. This sounds to me like a candidate for a macro ( but I don't at the
moment
know where to begin ). My main problem is that I can't work out how to make sure every
space is occupied by a segment. Although it would probably look good if not every
space
*was* occupied.
Thanks in advance if anyone can come up with any suggestions.
Andy
Subject: Re: Surface of a sphere
Date: 22 Feb 1999 00:09:08
Message: <36D0E686.54B15C64@virginia.edu>
Take a look at my macro for creating a sphere with Torii (in
text.scene-files) it isn't perfect, but should give you a start.
Steve
Andrew Cocker wrote:
> Hi all,
the
to
out
random
By
another
sphere
surface.
and
moment
every
space
> *was* occupied.
> Andy
Date: 22 Feb 1999 12:44:09
Message: <36D1984D.5F0C7315@spiritone.com>
You can start with a sphere and differnce out boxes rotate 18 degrees apart from one
another
like this:
difference {
  sphere { <0,0,0> 1 }
  box { <-2,-2,0> <2,2,2> rotate 9*x }
  box { <-2,-2,0> <2,2,-2> rotate =9*x }
 texture { foo }
If I understand you correctly, this will give you the wedge, but it will go from
horizon to
horizon (looks like an apple slice) If you want to give the top side a squarish shape
add a
third box to the difference statemet like this:
difference {
  box { <-2,-2,2> <0,2,2> rotate 9*z }
 texture { foo }
That should give the top a squarish shape that covers one quarter of the circumference
of the
sphere (give or take)
Throw of that into one object:
#declare MySlice =
  all that code above (I hate retyping and cutting and pasting)
Then put in objects :
object {MySlice}
object { MySlice rotate 18*x scale 1.2 }
ojbect { MySlice rotate 36*x scale 0.6 }
ad nauseum... this will let you adjsut each one, and scaling should work because taken
as a
whole, the original sphere was centered at the origin.
This does mean that all the slices are rotating around the x axis. If you want the
small
points of the slice to land on the y axis (which may be what you wanted in the first
place)
try this:
difference {
  box { <-2,0,0> <2,-4,-4> rotate 9*x translate 1*y }
  box { <-2,0,0> <2,-4,4> rotate -9*x translate 1*y }
  box { <-2,0,-2> <2,-2,2> }
  texture { foo }
this should give you one quarter slice. Now, (again, I hope I'm explaining all of the
theory
well enough) if you want the slices to cover a full half of the circumference it gets
a bit
more complicated:
difference {
  box { <-2,0,0> <2,4,-4> rotate -9*x translate -1*y }
  box { <-2,0,0> <2,4,4> rotate 9*x translate -1*y }
  texture { foo }
Now that gives you the slice. To place them individually  we would then add them to an
object
(as we did above, please don't make me retype it, I'm getting too verbose as it is)
and call
each ojbect individually:
object {MySlice rotate 18*n*y}
where n is any integer. TO do this automatically and randomize the sizes of each
slice:
#declare R1= seed(some number);
#declare RotationAmount = 0;
#declare MinScale = 0.5;
#declare MaxScale = 2.0;
#while (RotationAmount < 360)
  #declare ThisScale = rand(R1)*(MaxScale-MinScale) + MinScale;
  object { MySlice scale ThisScale  rotate RotationAmount }
  #declare RotationAmount = RotationAmount + 18;
All of this code is untested but should work barring any typos I can't see right now
Josh English
eng### [at] spiritonecom
www.spiritone.com/~english
> Hi all,
the
to
out
random
By
another
sphere
surface.
and
moment
every
space
> *was* occupied.
> Andy
Date: 22 Feb 1999 13:59:30
Message: <36d1a912.0@news.povray.org>
Now, let me see. You can make a 'square' cone with a rounded base, simply
by:
#local a=tan(radians(9));
intersection{
   sphere{0,1}
   prism {
     conic_sweep
     linear_spline
     0, // height 1
     1, // height 2
     5, // the number of points making up the shape...
      <a,a>,<-a,a>,<-a,-a>,<a,-a>,<a,a>
    scale 2
  rotate z*90
or something like that, but you will NOT be capable of building a sphere
from them, only a cross section, describing 9 degrees South to 9 degrees
North, if you rotate around the vertical axis.
To get pyramids to describe say 9 degrees North to 27 degrees north, you
need another base shape, representing some kind of trapezium, with one side
scaled by cos(radians(90-9-18)). This method leads to a
sphere with large patches at the equator, and fine patches at the poles.
A more promising method is the application of hexagons or triangles.
FRans
Andrew Cocker heeft geschreven in bericht <36d06de7.0@news.povray.org>...
>Hi all,
degrees of the
trying to
a sphere out
to apply random
originates from. By
while another
be a sphere
entire surface.
me know and
don't at the moment
sure every
every space
>*was* occupied.
>Andy
