POV-Ray : Newsgroups : povray.general : need some information Server Time
30 Nov 2025 15:43:19 EST (-0500)
  need some information (Message 1 to 6 of 6)
Subject: need some information
Date: 19 Mar 1999 04:56:09
Message: <36F22D8B.2BA3D3F8@yahoo.com>
Hello
I would like to know  if it is possible to render scenes containing
mathematical equations
such as ,let s say sqrt(x)=1.Instead of writing sqrt  I want to use the
following symbol:
I have tried to copy the sign from other documents (WORD)  paste it  on
pov's editor and render it as a text object but it did not work.
Thanks
nico
Subject: Re: need some information
Date: 19 Mar 1999 05:09:08
Message: <36F22166.512CF6A2@pacbell.net>
nico wrote:
> Hello
> following symbol:
> Thanks
> nico
  Your pretty much stuck with the current language I'm afraid to say.
It's much easier for the programmers to keep the language consistant
using a text based only language than it is to start introducing a
mix of symbols and text. Most people don't have the ability to enter
the non standard keyboard symbols any way and as you have said you were
forced to copy and paste it into the editor to even try it.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 19 Mar 1999 05:18:20
Message: <36f2246c.0@news.povray.org>
No Ken, I think he means as a text object... not in the scene description
language...
In that case you'll have to use a symbols font... a good one is aptly named
"Symbols".  Entering a normal letter like "d" for instance will give you the
delta symbol...
The Square-root symbol is character 214.
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Date: 19 Mar 1999 07:07:23
Message: <36F23DEF.53FFE10@peak.edu.ee>
You mean you want to make a 3D text object of the root sign? I don't think
this can be done, this is not a font character (in Word, I believe, it's a
MS Equation symbol). You have to model the sign manually. Shouldn't be too
difficult, though.
Margus
nico wrote:
> Hello
> following symbol:
> Thanks
> nico
Date: 19 Mar 1999 09:32:13
Message: <36F25E4A.2988F1DF@bahnhof.se>
don't forget that he'll need the unicode patch(I don't know where it is) to use
high ascii in the text object.
> language...
namX-Mozilla-Status: 0009ring a normal letter like "d" for instance will give you the
> delta symbol...
> Lance.
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Date: 19 Mar 1999 12:07:30
Message: <36F2847F.397731DF@compuserve.com>
nico wrote :
> following symbol:
> Thanks
You might also try to create a custom font with the adequate
symbols, taken from other fonts.  It will avoid you the
need for unicode patch.  Many utilities do that.
(if you have CorelDraw 3 (or up), it's possible)
Cheers,
Fabien.
