POV-Ray : Newsgroups : povray.general : Infinite (tiled) Heightfields Server Time
17 Mar 2026 06:34:03 EDT (-0400)
  Infinite (tiled) Heightfields (Message 1 to 8 of 8)
Subject: Infinite (tiled) Heightfields
Date: 22 Jan 1999 20:07:45
Message: <36A92132.37B0AC27@paradise.net.nz>
I had this idea, it's not particularly inspired (seemed fairly logical to me),
and i was just wondering what other ppl thought of it...
Currently, to create a decently size landscape, even a regular repeating one,
you have to make a really big heightfield or make copies, translated, of a
smaller one and bear the glitches running along the edges of each section - And
even then you have to make heaps of copies.  Anyway, it seems to me that by
making the bounding volume the intersection of two planes (ie, an infinite
"slab"), using modulus arithmetic, you could implement infinitely tiling
heightfields quite simply.
I shall refer to the bounding volume as the bounding slab, and the single
repeating heightfield unit as a tile...
If we say a function RayHits finds out where, if anywhere, the ray hits on a
single hf tile, then we can use the following recursive wrapper function to
extend functionality to infinitely tiled:
Function RayHitsHF(Ray) {
	Modulus the ray origin or entry point to find where on a single tile it
enters/starts
	If (RayHits) then return hitpoint
	else {
		If(Ray Exits Top or bottom) then return no intersection
		Else RayHitsHF(ray_exitpoint translated to the opposite edge of the tile
bounding box)
Some method of preventing endless loops would also probably be needeed
What do you think?
Sam Minnee
    mailto:smi### [at] paradisenetnz
    http://www.geocities.com/SiliconValley/Horizon/4152/
Ignorance is bliss - And don't you go telling me otherwise!
Subject: Re: Infinite (tiled) Heightfields
Date: 22 Jan 1999 20:30:01
Message: <36A92515.9091B0E7@bahnhof.se>
This sounds like a very good idea...
then one could use procedural textures for a hf... Very interesting...
//Spider
> enters/starts
>         else {
tile
> bounding box)
> What do you think?
> Sam Minnee
Date: 25 Jan 1999 08:53:39
Message: <36ac7763.0@news.povray.org>
Um... one can already use procedural textures for a hf, though with
the same limitations as apply to all heightfields.  Grab a copy of
the Superpatch if you don't already have it.
Date: 25 Jan 1999 09:04:27
Message: <36ac79eb.0@news.povray.org>
On Sat, 23 Jan 1999 14:09:06 +1300, The Crazy Mule
>enters/starts
>	else {
>bounding box)
You'll still have glitches along the edges, unless you use a tileable
image and kludge the hf to wrap around correctly.  But why should it
be recursive?  It seems like you're just following the ray through a
virtual "grid" of heightfields, finding any intersections for each
instance of the heightfield.  No need for recursion there.  You will,
as you say, have to terminate somehow.  I can't think of any way to
detect a ray that is parallel to the bounding slab but that does not
intersect the height field at any point, so maybe you'd have to bail
out after traversing a set number of grid squares or a set distance.
This isn't a bad idea, and it seems far easier to implement than one
might at first think.  A further modification might be to "flip"
adjacent copies of the HF along the appropriate axes, to make it
tile relatively smoothly without the need for a tileable image.
Date: 25 Jan 1999 12:24:51
Message: <36aca8e3.0@news.povray.org>
In article <36ac79eb.0@news.povray.org> , par### [at] my-dejanewscom (Ron
Hmm, if I understand it right the heightfield is bounded by two parallel
planes, so all you need to test is if a ray is parallel one of the planes
(which is easy). Then you test is there is any intersection with this ray
and the heightfields within the first 2*sqrt(2) (for a heightfield scaled to
1 only) and you are done.
      Thorsten
Date: 25 Jan 1999 12:47:13
Message: <36acae21.0@news.povray.org>
On Mon, 25 Jan 1999 11:24:47 -0600, Thorsten Froehlich
Not necessarily.  If you're using tiled heightfields as described here,
and the tile is a high resolution and consists of all zeros except
for a 1 in the exact center (at (.5,.5)), there are an infinite number
of rays which will not intersect within the space of two tiles but will
intersect at some point beyond that (consider the ray that starts at
(0,0) and proceeds in the direction of (.5,5.5)), and there are an
infinite number of rays that will never intersect at all (consider the
ray that starts at (0,.5) and proceeds due northeast).
Date: 26 Jan 1999 02:46:49
Message: <36AD733F.84163C9B@paradise.net.nz>
Ummm, is anyone who is familiar with the POV source interested in implementing
this?
> enters/starts
>         else {
tile
> bounding box)
> What do you think?
> Sam Minnee
Sam
Date: 26 Jan 1999 02:47:08
Message: <36AD734C.54D8932C@paradise.net.nz>
Thanks for all your comments
this?
> enters/starts
>         else {
tile
> bounding box)
> What do you think?
> Sam Minnee
Sam
