POV-Ray : Newsgroups : povray.general : Q: Rand Server Time
24 Jun 2026 21:05:21 EDT (-0400)
  Q: Rand (Message 1 to 5 of 5)
Subject: Q: Rand
Date: 1 Jan 1999 07:52:34
Message: <368CC4A7.155EDF35@pacbell.net>
Is it possible to add a random +/- function to a loop ?
For example I have a loop that is making several copies of an object
and I wish to apply a random rotation of say -20*y to +20*y as the
objects are being translated by the loop. Is this possible ?
Ken Tyler
tyl### [at] pacbellnet
Subject: Re: Rand
Date: 1 Jan 1999 09:40:11
Message: <368cde4b.0@news.povray.org>
I think so, yes.
an object
as the
a random number is between 0 and 1, so if you want to use a
random rotation up to twenty, you can obviously use
20*rand(R) to do the trick
Now if you also wish to use negative numbers up (down?)
to -20, you have to subtract 20,
20*rand(R)-20
This 'creates' numbers between -20 and 0.
If you want numbers between -20 and 20, it would look like
this:
40*rand(R)-20
So your rotation would be like :
#declare seed(R)=1999 (happy new year)
rotate <0,40*rand(R)-20,0>
Hope this helps
Julius
http://surf.to/jkhome
Subject: Re: Rand
Date: 1 Jan 1999 09:42:41
Message: <368CDE77.9818D7D4@pacbell.net>
> I think so, yes.
> an object
> as the
> 20*rand(R)-20
> this:
> 40*rand(R)-20
> Hope this helps
> Julius
Perfect ! Thank you !
Ken Tyler
Subject: Re: Rand
Date: 1 Jan 1999 22:16:10
Message: <368d8f7a.0@news.povray.org>
I created a macro to do exactly that; you can get it from Twyst's
Macroscope; it's called rand_ext.
Margus
Ken wrote in message <368CC4A7.155EDF35@pacbell.net>...
>Ken Tyler
Subject: Re: Rand
Date: 2 Jan 1999 03:37:40
Message: <368DDA69.D291EB77@pacbell.net>
> Margus
 Thank you. I'll check it out.
Ken Tyler
