POV-Ray : Newsgroups : povray.general : Cubic_Spline Lathe Problem ? Server Time
12 Jan 2026 17:42:55 EST (-0500)
  Cubic_Spline Lathe Problem ? (Message 1 to 3 of 3)
Subject: Cubic_Spline Lathe Problem ?
Date: 21 Dec 1998 04:22:31
Message: <367E1306.57CB@pacbell.net>
Seasons Greetings !
  The Pov text below describes a closed curve shape
(like a serving tray). I want to use the cubic spline
to help give me smooth curves with a limited amount
of control points. Problem is when I use cubic verses
linear of quadratic the closed curve section of the
shape gets cut out. Would somebody check this out
and tell me if I'm applying this wrong or if it's
just not behaving properly.
Thanks
 Ken Tyler
 tyl### [at] pacbellnet
  lathe{
  cubic_spline
  // quadratic_spline
  //linear_spline
  13,
  <0.00, 0.00>,
  <2.00, 0.00>,
  <2.20, 0.10>,
  <2.30, 0.20>,
  <2.30, 0.25>,
  <2.50, 0.26>,
  <2.52, 0.27>,
  <2.30, 0.28>,
  <2.29, 0.27>,
  <2.20, 0.20>,
  <2.10, 0.19>,
  <1.90, 0.18>,
  <0.00, 0.17>
  pigment{rgb .7}
  finish{ambient .4 diffuse .3}}
  camera{location<0,  7, -8> look_at 0 }
  light_source{  <0,100,-33> rgb 1}
Subject: Re: Cubic_Spline Lathe Problem ?
Date: 21 Dec 1998 06:08:41
Message: <367E2C16.7D5D@t-online.de>
Ken wrote:
> Seasons Greetings !
>.....pov-code
Hello Ken,
using cubic_spline povray will take the first and the last of your <u,v>
coordinates as mere control points for the slope of the spline at the
second and the last_but_one coordinate.
So try out something like following, and it will work correctly:
//pov-code:
lathe{
  cubic_spline
  //quadratic_spline
  //linear_spline
  15,
  <0.00, 0.17>
  <0.00, 0.00>,
  <2.00, 0.00>,
  <2.20, 0.10>,
  <2.30, 0.20>,
  <2.30, 0.25>,
  <2.50, 0.26>,
  <2.52, 0.27>,
  <2.30, 0.28>,
  <2.29, 0.27>,
  <2.20, 0.20>,
  <2.10, 0.19>,
  <1.90, 0.18>,
  <0.00, 0.17>,
  <0.00, 0.00>,
  pigment{rgb .7}
//end of pov-code
Merry christmas
ReVerSi
Date: 21 Dec 1998 18:10:40
Message: <367ED51A.9A0@pacbell.net>
ReVerSi wrote:
> Hello Ken,
> Merry christmas
> ReVerSi
Thank You !
 Ken Tyler
