![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Does anyone know how to make a true spiral texture, like that of a candy
cane. I know you can use grandient x+y to simulate one but that only works
if you have the proper angle. I want to be able to animate it so I need it
to really spiral up the object.
Any help would be appreciated,
Thanks,
Darcy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How about spiral1 pigment type? That should do the trick!
Lance.
For the latest MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Darcy Johnston wrote in message <3671d1e1.0@news.povray.org>...
>Thanks,
>Darcy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Lance Birch wrote in message <3671d394.0@news.povray.org>...
Ok, I think this puts me down under dink of the day. :)
I thought I had done a search in the pov manual for Spiral, but obviously, I
must have checked for some other word instead. Sorry about that.
Thank you very much.
Darcy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darcy Johnston <dmj### [at] home com NOSPAM> wrote:
: Does anyone know how to make a true spiral texture, like that of a candy
: cane. I know you can use grandient x+y to simulate one but that only works
: if you have the proper angle. I want to be able to animate it so I need it
: to really spiral up the object.
Are you talking about a spiral shape or a helix shape? The spiral
texture is a spiral, not a helix, so it may not help you.
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I understand what the difference between spiral and helix is
for POV, but I was just wondering what (as a language thing)
the difference between a "spiral" and a "helix" is. I always
thought they meant the same thing.
Julius
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Nieminen Mika wrote in message <3672459a.0@news.povray.org>...
works
it
I guess I mean a helix shape since I want the texture to spiral up a column.
Like I said, I want something like the stripe on a candy cane. I've been
able to simulate it as I mentioned above, but I'm looking for something that
I can view from all angles.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ok, I went with the spiral1 pattern and I was able to get what I wanted.
Since I was using up = y, I had to rotate the pattern in order to get the
orientation right.
So by using
pigment {swirl1 4 rotate x*90}
I was able to get the effect I wanted. Now all I need to do now is set the
pigment modifiers to get the right colors in there and scale it properly.
Thanks to everyone,
Darcy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
open textures.inc
scroll down
at almost the bottom,. you'll find the texture declared...
Copy that to your source, declare as MySprialThing or something, then change it...
//Spider
> orientation right.
> So by using
> Thanks to everyone,
> Darcy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Julius Klatte <jku### [at] hotmail com> wrote:
: I understand what the difference between spiral and helix is
: for POV, but I was just wondering what (as a language thing)
: the difference between a "spiral" and a "helix" is. I always
: thought they meant the same thing.
Maybe I'm wrong, but this is what I have understood:
AFAIK: A spiral is a line on a 2D plane which can be drawn this way:
start drawing a circle but increase the radius constantly. When you have
made a complete 360 degrees curve, you are a little bit farther away from
the center. Continue drawing and you get a spiral curve.
A helix is a 3D line instead of 2D like the spiral. You can draw it this
way: start drawing a circle in the xy-plane, but instead of changing the
radius, keep it constant, but increase the z-coordinate, ie. the height.
When you have done a complete 360 degrees curve, you are still at the same
distance from the center axis, but a little bit higher from the plane.
Continue this way and you get a helix curve.
A galaxy has typically a spiral shape, while a spring has a helix shape.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually, I believe a helix is a spiral, but a spiral is not a helix... Never
mind, though. You are correct.
So how do you call the shape where both the radius and the height increase?
Spiralling helix? Helical spiral? Just curious.
Margus
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
