POV-Ray : Newsgroups : povray.general : Spiral texture Server Time
30 Nov 2025 22:37:15 EST (-0500)
  Spiral texture (Message 1 to 10 of 19)
Subject: Spiral texture
Date: 11 Dec 1998 21:16:01
Message: <3671d1e1.0@news.povray.org>
Does anyone know how to make a true spiral texture, like that of a candy
cane. I know you can use grandient x+y to simulate one but that only works
if you have the proper angle. I want to be able to animate it so I need it
to really spiral up the object.
Any help would be appreciated,
Thanks,
Darcy
Subject: Re: Spiral texture
Date: 11 Dec 1998 21:23:16
Message: <3671d394.0@news.povray.org>
How about spiral1 pigment type?  That should do the trick!
Lance.
For the latest MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Darcy Johnston wrote in message <3671d1e1.0@news.povray.org>...
>Thanks,
>Darcy
Date: 11 Dec 1998 21:54:08
Message: <3671dad0.0@news.povray.org>
Lance Birch wrote in message <3671d394.0@news.povray.org>...
Ok,  I think this puts me down under dink of the day. :)
I thought I had done a search in the pov manual for Spiral, but obviously, I
must have checked for some other word instead. Sorry about that.
Thank you very much.
Darcy
Date: 12 Dec 1998 05:29:46
Message: <3672459a.0@news.povray.org>
Darcy Johnston <dmj### [at] homecomNOSPAM> wrote:
: Does anyone know how to make a true spiral texture, like that of a candy
: cane. I know you can use grandient x+y to simulate one but that only works
: if you have the proper angle. I want to be able to animate it so I need it
: to really spiral up the object.
  Are you talking about a spiral shape or a helix shape? The spiral
texture is a spiral, not a helix, so it may not help you.
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Subject: Re: Spiral or helix?
Date: 12 Dec 1998 09:48:36
Message: <36728244.0@news.povray.org>
I understand what the difference between spiral and helix is
for POV, but I was just wondering what (as a language thing)
the difference between a "spiral" and a "helix" is. I always
thought they meant the same thing.
Julius
Date: 12 Dec 1998 11:33:22
Message: <36729ad2.0@news.povray.org>
Nieminen Mika wrote in message <3672459a.0@news.povray.org>...
works
it
I guess I mean a helix shape since I want the texture to spiral up a column.
Like I said, I want something like the stripe on a candy cane. I've been
able to simulate it as I mentioned above, but I'm looking for something that
I can view from all angles.
Date: 12 Dec 1998 11:42:18
Message: <36729cea.0@news.povray.org>
Ok, I went with the spiral1 pattern and I was able to get what I wanted.
Since I was using up = y, I had to rotate the pattern in order to get the
orientation right.
So by using
    pigment {swirl1 4 rotate x*90}
I was able to get the effect I wanted. Now all I need to do now is set the
pigment modifiers to get the right colors in there and scale it properly.
Thanks to everyone,
Darcy
Date: 12 Dec 1998 12:40:09
Message: <3672A9CC.C4336E49@bahnhof.se>
open textures.inc
scroll down
at almost the bottom,. you'll find the texture declared...
Copy that to your source, declare as MySprialThing or something, then change it...
//Spider
> orientation right.
> So by using
> Thanks to everyone,
> Darcy
Date: 14 Dec 1998 05:37:06
Message: <3674ea52.0@news.povray.org>
Julius Klatte <jku### [at] hotmailcom> wrote:
: I understand what the difference between spiral and helix is
: for POV, but I was just wondering what (as a language thing)
: the difference between a "spiral" and a "helix" is. I always
: thought they meant the same thing.
  Maybe I'm wrong, but this is what I have understood:
  AFAIK: A spiral is a line on a 2D plane which can be drawn this way:
start drawing a circle but increase the radius constantly. When you have
made a complete 360 degrees curve, you are a little bit farther away from
the center. Continue drawing and you get a spiral curve.
  A helix is a 3D line instead of 2D like the spiral. You can draw it this
way: start drawing a circle in the xy-plane, but instead of changing the
radius, keep it constant, but increase the z-coordinate, ie. the height.
When you have done a complete 360 degrees curve, you are still at the same
distance from the center axis, but a little bit higher from the plane.
Continue this way and you get a helix curve.
  A galaxy has typically a spiral shape, while a spring has a helix shape.
Date: 14 Dec 1998 07:01:37
Message: <3674FDE8.55CE1423@peak.edu.ee>
Actually, I believe a helix is a spiral, but a spiral is not a helix... Never
mind, though. You are correct.
So how do you call the shape where both the radius and the height increase?
Spiralling helix? Helical spiral? Just curious.
Margus
