POV-Ray : Newsgroups : povray.general : Continued render in POV 3.1a win 95 goes BOOM Server Time
14 Oct 2024 20:15:28 EDT (-0400)
  Continued render in POV 3.1a win 95 goes BOOM (Message 1 to 6 of 6)
Subject: Continued render in POV 3.1a win 95 goes BOOM
Date: 9 Dec 1998 12:29:01
Message: <366EB2B2.C54D8872@bahnhof.se>
Well.. The topic says it..
My pov goes down when resuming a rendering...
It is my final render, 1024x768x48bpp, radiosity on(rather high) antialisaing mode 2,
recursive 4 ....
So, it takes a while...
But, I had to abort it(chaos, needed the printer....) and since I always have
continued
trace on, I did that..
But when resuming, it went Kapoof...
It reads the prev. image, does the radiosity check (prel. looking very blurred) and
then
goes down on me... Why ??? Is it a bug, does anyone else have this ??
I really want to resume it... (it renders at around 2pps) ..... I have a 166MMX...
Help, please..
//Spider
Subject: Re: Continued render in POV 3.1a win 95 goes BOOM
Date: 9 Dec 1998 14:08:51
Message: <366ecac3.0@news.povray.org>
In article <366EB2B2.C54D8872@bahnhof.se> , Spider <spi### [at] bahnhofse>  wrote:
Also I don't know why it crashes, you can use partial rendering to render the missing
lines and them combine the two images with another program.
    Thorsten
Date: 9 Dec 1998 14:15:25
Message: <366ECBA6.7E941E57@bahnhof.se>
Yes... I could do that, but I'm more irritated by the fact that it crashes...
Thanx for the tip....
//Spider
missing
>     Thorsten
Date: 10 Dec 1998 06:32:16
Message: <366fb140.0@news.povray.org>
Thorsten Froehlich <fro### [at] charliecnsiitedu> wrote:
: Also I don't know why it crashes, you can use partial rendering to render the
missing
: lines and them combine the two images with another program.
  Partial rendering and radiosity is not a good combination. You will probably
get the two parts with differenct coloration. I discovered this when I
made a radiosity image by calculating the upper half of the image on one
computer and the lower half on another (400MHz Alphas if I remember right).
  When I joined the images, the dividing line was _very_ visible.
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Date: 10 Dec 1998 10:43:32
Message: <366fec24.0@news.povray.org>
In article <366fb140.0@news.povray.org> , Nieminen Mika <war### [at] assaricctutfi>
Oh, interesting! Then the radiosity buffer is not generated for the whole image.
This effect is a bug! I will forward it to the team.
    Thorsten
Date: 11 Dec 1998 11:22:10
Message: <367146EE.F34A0274@Kopp.com>
>     Thorsten
Although it could probably be considered a 'bug', it's not worth bothering the
POV-Ray team with.  I'm pretty sure that they know about it, and there's not
much they can easily do about it because of the way POV's radiosity works,
since the 'radiosity buffer' is generated on-the-fly as the image is rendered.
Probably providing some overlap of pixels when rendering partial images could
make the dividing line less visible.
-Nathan
