POV-Ray : Newsgroups : povray.general : Using 'frame number' in #switch (=Bob) Server Time
25 Jun 2026 00:54:53 EDT (-0400)
  Using 'frame number' in #switch (=Bob) (Message 1 to 5 of 5)
Subject: Using 'frame number' in #switch (=Bob)
Date: 2 Dec 1998 15:57:17
Message: <3665a9ad.0@news.povray.org>
    =Bob pointed me in the right direction with this one, but I'm still
having difficulties.
I want to use
#switch (FC)
where frame count FC=frame number
but how do I #declare FC to equal whatever frame the animation is rendering
at any one point, ie on frame 45 - FC=45.
thankyou,
Andy
and### [at] acockerfreeservecouk
Subject: Re: Using 'frame number' in #switch (=Bob)
Date: 2 Dec 1998 20:45:50
Message: <3665ed20.102278195@news.povray.org>
On Wed, 2 Dec 1998 20:56:50 -0000, "Andrew Cocker"
<and### [at] acockerfreeservecouk> wrote:
>I want to use
>#switch (FC)
I think you can use
#declare FC=clock/clock_delta + StartingFrameNumber
assuming your clock goes from 0 to 1, but you'll have
to set StartingFrameNumber yourself.
Date: 2 Dec 1998 22:58:49
Message: <36660c79.0@news.povray.org>
Oops, sorry, I neglected to point out that an INI file is needed (or
command-line switches) telling the animation to use the clock for a frame
count, not frame numbers (still use frames though). As in:
Initial_Clock=0
Final_Clock=59
for a 60 frame animation.
Or +ki0 +kf59 command-line style.
And then #declare FC=clock in your scene file.
This neccessitates a new clock value for getting back to a regular old clock
of 0 to 1 however.
#declare _C_ = clock/59
is how I do it. This is basically Ronald L. Parkers suggestion below.
It does get messy as you can plainly see, especially if other parameters are
wanted for frame count (start/end too), clock values, etc.
Trying to make a clock 0 to 1 in the usual way and telling your scene file to
use a int(clock*60) is a possibility but I don't trust the math.
Hope your on your way well enough now ;)
Message <3665ed20.102278195@news.povray.org>, Ronald L. Parker typed...
>>I want to use
>>#switch (FC)
>I think you can use
  http://members.aol.com/inversez/POVring.html
=Bob
Date: 3 Dec 1998 08:44:55
Message: <366695d7.0@news.povray.org>
Except that clock_delta is a reserved word in 3.1, and it evaluates
to the difference between the clocks for two consecutive frames.
Thus, the only thing you need is the starting frame number.
Date: 3 Dec 1998 15:21:55
Message: <3666f2e3.0@news.povray.org>
Good to know, thanks.
Message <366695d7.0@news.povray.org>, Ron Parker typed...
=Bob
