POV-Ray : Newsgroups : povray.general : help needed!! -- tricolour triangles Server Time
12 Sep 2025 00:01:19 EDT (-0400)
  help needed!! -- tricolour triangles (Message 1 to 3 of 3)
Subject: help needed!! -- tricolour triangles
Date: 3 Nov 1998 10:52:31
Message: <363F26B8.604FC68F@ica.uni-stuttgart.de>
Has anyone experiene with the old (for povray 3.0) Tri-colour Triangles
include file from Chris Colefax? I downloaded it yesterday from his
homepage together with the instructions and tried to use it. The problem
is that I use an unofficial povray version 3.01 compiled for a SGI O2. I
have no official installation here at work.
My file looks like this:
//***** beginning of file
location <2,2,2>
look_at  <0,0,0>
light_source {<2,2,2> color rgb<1,1,1>}
#declare P1 =<0.0, 0.0, 0.0>
#declare P2 =<1.0, 0.0, 0.0>
#declare P3 =<0.0, 1.0, 0.0>
#declare C1 =<1,1,1>
#declare C2 =<1,1,1>
#declare C3 =<1,1,1>
include "tricol.inc"
//***** ending of file
When I run this file I get a error message during parsing (I did this
with two different binaries):
Parsing...tricol.inc:52: warning: Pigment type unspecified or not 1st
item.
      rotate _TC_XZroty rotate _TC_normrotx + _TC_normroty translate P1}
   #if (texture_only = false) triangle {P1, P2, P3 #end
      pigment {average pigment_map {
         [1 onion pigment_map {[0 C1] <----ERROR
tricol.inc:52: error: ] expected but vector function 'vector identifier'
found instead.
I looked through the include file but I am not very familar with the
math for mapping the pigments and I don't believe that there is an error
in Chris Include File. So where is mine?
Any help appreciated!
TIA,
Marc
Marc Schimmler
Subject: Re: help needed!! -- tricolour triangles
Date: 5 Nov 1998 13:21:23
Message: <3641EC79.33E@merlin.net.au>
> camera {
> location <2,2,2>
> look_at  <0,0,0>
> item.
> found instead.
> TIA,
> Marc
> Marc Schimmler
I haven't used the tricolor include file, but it looks to me like it
wants colour values for C1-C3.
Try
#declare C1 = rgb<1,1,1>
#declare C2 = rgb<1,1,1>
#declare C3 = rgb<1,1,1>
Best of luck,
	PoD.
Date: 6 Nov 1998 02:28:19
Message: <3642A512.1D35029A@ica.uni-stuttgart.de>
> > camera {
> > location <2,2,2>
> > look_at  <0,0,0>
> > item.
> > found instead.
You got it!!
Thank you very much! This helped me out of a dire situation!
With regards,
Marc
Marc Schimmler
